Another 4th Gen wheel question...
Old Aug 15, 2011 | 11:22 PM
8T9Formula's Avatar
Car: 1989 Formula
Engine: 5.0
Transmission: 5 sp
Axle/Gears: 3.45:1
Greetings all, long time car guy, first time 3rd Gen owner...
Recently bought an 89 Formula with some weird and badly corroded TTIIs with heavily worn tires and I need a change.
Original factory wheels would be my first choice but can't seem to locate any in my area in my price range, so:
I saw this pic of a Formula like mine sporting these 4th Gen Firebird wheels...
And thought it looked pretty good, and there is a set of these wheels with good tires for sale not far away and in my price range...
...so my questions is, if I were to buy these wheels, do I need spacers? Front and rear? Front only? Rear only?
You get the idea.
Thanks for any advice you can give!
Old Aug 15, 2011 | 11:31 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Another 4th Gen wheel question...
Yep. You'll hafta buy adapters for them to fit up front. For the rear, you can swap in a complete 4th gen axle & then you wouldn't need the adapters out back. But there is no way around needing adapters for the front.
IMHO, by the time you buy wheels & adapters, you can just buy wheels that fit & not end up having 40 lug nuts + the extra parts (the adapters) weight.
Old Aug 16, 2011 | 12:04 AM
8T9Formula's Avatar
Car: 1989 Formula
Engine: 5.0
Transmission: 5 sp
Axle/Gears: 3.45:1
OK, thanks. BTW, for the sake of argument, what size adapters would I need? Couldn't afford a 4th Gen axle so sounds like would need adapters for the rear too?
Considering all options for stretching my limited $$$
Thanks again!
Old Aug 16, 2011 | 12:28 AM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Thanks again!
2 inch adapters for 4th gen wheels.
Old Aug 16, 2011 | 10:46 PM
8T9Formula's Avatar
Car: 1989 Formula
Engine: 5.0
Transmission: 5 sp
Axle/Gears: 3.45:1
Helpful info, thank you. I think I'll just start with tires on the existing TTIIs, polish them up best I can and save my pennies for the right wheels/tires at a later time.
Omega
Oct 1, 2015 02:20 PM
cam-mike
Aug 24, 2015 07:23 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
