I need some real wheel advice.
Old Aug 15, 2011 | 09:40 PM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
Wheel Diameter 17 in.
Wheel Width (in) 9.500 in
Wheel MaterialAluminum
Primary Wheel Color Polished
Wheel Finish Polished
Manufacturers Wheel Series Center Line Competition Split Spoke Series
Backspacing (in) 4.500 in.
Offset -19.00mm
Wheel Construction2-piece
How exactly do I go ahead and fit these wheels on my car without seriously modifying the wheel wells. Thank you all in advance for your advice.
Or if anyone knows if these wheels come in a size that fits without spacers, that would be great as well.
Old Aug 15, 2011 | 09:42 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: I need some real wheel advice.
thats not enough BS, they will probably stick just outside the fenders and rub the fenders when you turn. You typically need 5-5.5" of bs for a 17x9.5" wheel. the stock Ronal 17x9.5 is 5.25 i believe
Old Aug 15, 2011 | 09:44 PM
Car: 1992 RS 6spd
Okay, so if I have more back spacing, the offset isn't going to hurt? I'm so confused when it comes to wheel sizes.
Old Aug 15, 2011 | 09:47 PM
Car: 1992 RS 6spd
http://www.summitracing.com/parts/CLL-7277957547/
So these wheels will work? Sorry I'm completely retarded when it comes to wheel sizing.
And these for the front?
http://www.summitracing.com/parts/CLL-7277807547/
Old Aug 16, 2011 | 06:02 PM
Car: 1992 RS 6spd
Somebody?
Old Aug 16, 2011 | 07:22 PM
Car: 1992 RS 6spd
The site was down, so I didn't make the recent post cut. I kinda need to know about these, looking to buy this week.
Old Aug 16, 2011 | 08:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Back spacing, is the measurement from the back of the wheels lip, to the mounting surface of the wheel. Offset is the distance from the center of the physical wheel to the wheels mounting surface. So if you change the BS, the offset changes.
17x8 for the front would want 4.5" of BS, or a zero offset. those 17x9.5 rears with 5.5 " of BS will be fine, but 6" would tuck in a little better. Both will work though.
The sticky at the top of the page is full of good info
https://www.thirdgen.org/forums/whee...er-wanted.html
maybe give it a read before buying wheels, its not something to dive into without doing your homework, you can make some expensive mistakes.
and, as usual, a search of this topic would have yielded the same info.
Old Aug 17, 2011 | 06:37 AM
Car: 1992 RS 6spd
Thanks a lot, I read the sticky. I'm just having a hard time understanding the relation between bs and offset, and how it works on our specific cars. If you needed some paint work done, which is my specialty, I'd help ya just for the advice on the wheels lol.
TrevinE
Sep 14, 2015 03:20 PM
scottmoyer
Sep 7, 2015 07:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
mrdevontay
Sep 2, 2015 08:04 PM
