15x8 Prostars w/ 5.5 backspacing needs spacers?
I just put them on and it looks like I needed to put spacers on, so I did. I don't recall ever reading this was needed. Does this sound right? Just want to make sure my wheels don't fly off while racing!
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 15x8 Prostars w/ 5.5 backspacing needs spacers?
why do you need spacers? if they are touching the body, clearance the body. some hammering is very normal.
FWIW, 8" wheels are generall 4.5" of BS
I think it was the tip of the inner wheel well that was touching it. It is fine with the spacer, but it didn't feel fine w/out it.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Yep, most 8" wheels are 4.5 on thirdgens. I run 5.5" backspacing on my 15x8's but I run a 4th gen rear thats wider by 1.75" or so each side.
