removing Power Steering pressure hose
Old Aug 24, 2011 | 03:02 PM
rcyoung's Avatar
Car: 1991 Firebird
Engine: V6 3.1L
Transmission: Automatic
HELP!! I have a leak in my PS pressure hose in my 1991 3.1L V6 Firebird. I bought the new hose and am ready to install, but I am having major problems simply removing the old hose. I am trying to use an standard open wrench, but it seems that the return hose and other things are in the way. Should I use another tool? Remove the tire for more room? use some liquid wrench to help it along? Let me know what you think!
Old Aug 25, 2011 | 11:31 PM
dead sailor's Avatar
Car: 82 Z28
Engine: 355 solid roller (395 stroker soon)
Transmission: t-56
Axle/Gears: 9 bolt posi
Re: removing Power Steering pressure hose
You need what is called a crow's foot. Using an open end wrench may strip out the head on the fitting.
Old Oct 22, 2011 | 02:19 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
if your looking to buy the tool.
its called a line/tubing wrench.
hits more points on the shoulder of the nut.
crows foot is a dif tool altogether
and they also make a crows foot line wrench.
**crows foot looks like just the cut off head of a open end wrench.**
most of the time set up to fit a 3/8 ratchet
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
Bull86
Aug 10, 2015 05:43 PM
3rdgenparts
Aug 8, 2015 07:09 PM
