Getting XXR 521 on thursday
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: Getting XXR 521 on thursday
Once you get the tires mounted it will be much easier for you to determine potential clearance issues. Are you talking about custom center caps because the dust cap sticks out too far for you to put the ones that came with the wheel? Mine were like that but someone suggested just massaging the dust cap in until the center cap fits. No issues, and they do fit.
Yea I know I can message them in a bit but I think some custom ones would look better than the ones that come I'm going to use apart of the center cap cut the center out and make a carbon fiber one instead
So which dimensions did you go with again?
First post it was staggered but all the boxes are 18 X 10?
Sorry if i missed something posted before..
Engine: 305 to 350
Axle/Gears: 10 Bolt
yes there are 18x10 all around !
NOt staggered
Yes the first post it was staggered setup for the 89 rs camaro i had but that camaro ended in a sad story the mechanic i had was running a chop shop posted the what happen in one of the post above
but anyways decided to head in different direction and got 18x10 all due to better handling and to get a more agressive mean look and i just like the look better instead of the staggered setup 18x10 rear and 18x8.5 in front i had Budnik Gassers 18x10 and 18x8 and wasnt digging the narrow width wheel in front
NOt staggered
NOt staggered
Engine: 305 to 350
Axle/Gears: 10 Bolt
they only come in +25 that ive seen for the 18x10 what size you are looking at
Engine: 305 to 350
Axle/Gears: 10 Bolt
oh ok whats it going on camaro or firebird?
what wheels ? same as mines ?
should look at VBR Wheels i was looking at those too and they have pretty good offsets
yea i cant wait myself just havent have time to put tires on
I really want a pair of ccw classics, but I'm going to have to hold off on those for a little while.
VBR? I couldn't find them on google..
Engine: 305 to 350
Axle/Gears: 10 Bolt
ccws are nice i was looking at fiske,vmr and or forgeline wheels but i daily drive my car so ill wait on that and anyways i rather save up for a engine swap in the future
and stick with the budget build idea
mybad there VMR Wheels there bmw fitment
Engine: 305 to 350
Axle/Gears: 10 Bolt
Engine: 305 to 350
Axle/Gears: 10 Bolt
He goes some teaser pics just one used tire too recheck clearance before getting new ones
Engine: 305 to 350
Axle/Gears: 10 Bolt
Sorry for car being dirty I drive it everyday lol
So it looks like I can run a 1inch spacer all around the front tucks in perfect with the 1.25inch spacer but rear sticks out 1/4 inch so I might just run 1inch spacer in the rear instead off 1.25inch to tuck it in bit more I do need to roll the rear fenders and the fronts I need to roll also just to be safe I do need to remove the front liner
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
XXR's are hitting the third gen community like they did and left the 240/miata community..
cheap, good looking wheels but be ready for imitators
Engine: 305 to 350
Axle/Gears: 10 Bolt
many people has done many things to thirdgens only a handful maybe more actually post what they do on here so what one person done probably another person has done that also people are going to imitate even if they don't realize it lol....
Unless your driving something like this
with a duramax diesal twin turbo that be different but i think a guy is doing that swap on this forum or a viper engine but that's been done also
How bout a Toyota supra 2jz engine in a thirdgen ..... Can handle 800+ on stock bottom end but that be a love hate type of thing
Nissan powered mustang
http://www.hotrodhomepage.com/hrhp/2...wered-mustang/
but anyways enough day dreaming
This is a budget build that I drive everyday and doesnt hurt my pocket so I don't mind that ..most people on thirdgen are cheap same with 240/miata crowd..so they go for swap meet deals or cheaper version of parts you can find these cars cheap all day long.. if my thirdgen wasn't a daily driver I probably put the best of the best of every part I can get my hands but then I would only want to drive it in the weekends or only on sunny days what fun is that
Car: 92 Camaro Rs.R
Transmission: wc t-5
ok bro.... finaly!!!! hahaha it came out siiiiick
im stoked . waiting for my black ones. looks like ill be running 18*10 up front too lol
Car: 1991 Firebird
Engine: 3.1L V6
You need a full side shot! Pull the car out of the parking spot(without turning the wheels) and snap a shot. Looks good though. Like how the color of the wheel matches your IROC door decal.
The rears you should be able to put the 1in spacer and not have to roll the fenders. I didn't roll mine.
Car: 1991 Firebird
Engine: 3.1L V6
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Front looks good, but too much spacer on the rear.
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea those 1.25 spacers I was going to use for another pair of wheels but UPS lost 3 lol I'm going to get a 1inch spacer
Is that what your running in the rear ? Your wheel is a 10.5 if I'm not mistaken
Engine: 305 to 350
Axle/Gears: 10 Bolt
Thanks You after putting the rear on I was surprised the front tuck in so good thought it was going to stick out like the rear But yes smaller spacer is going to be used for rear
Do you know the difference between front and rear ? Looks like rear sticks out 1/4 inch compared to front Just curious seems on why wheel sticks out more
Your right that it was going to tuck more with full weight on wheels
Engine: 305 to 350
Axle/Gears: 10 Bolt
Car: 92 Camaro Rs.R
i may not get the 521 after all, i just saw the 530..... little more work to get them to fit. bit i love them so its worth it lol
Engine: 305 to 350
Axle/Gears: 10 Bolt
yea funny thing i was looking at those same wheels i use to have a pic with them mounted wont need much to make it fit but diffently need a adapter they look pretty sweet on camaro gave it a euro modern look i guess
Car: 92 Camaro Rs.R
do you still have the pic? im having a problem doing the math to make sure the measurments are correct for the front, i wanted to do the 18*8.75 up front but idk if it will fit quite right....maybe do 9.75 all 4
Car: 92 Camaro Rs.R
and what size spacer / addapter i would need up front ... if i use the 18*8.75 with 20mm back spacing
Car: 1991 Firebird
Engine: 3.1L V6
The 530 does look good but, try looking at different brands with that similar style instead of trying to adapt a 5x114 wheel to fit our 5x120.65
Engine: 305 to 350
Axle/Gears: 10 Bolt
for 9.75 all around you probably need 1.25 or 1.5 spacer all around
for 8.75 needs 1inch allaround the +35 offset needs a 1 inch spacer too
i tried 18x9.75 with 275 35 im trying to look for pic but think i deleted it on phone
not trying too get on you but that set up is a pain
they look good but just to much of a pain they come in 8.75 and 9.75 i personally dont like the STRETCH tire look on a camaro another and those width where design so you can achieve the stretch tire look another issue is if you get a flat you have to take off spacer and the wheel to mount your spare tire only a handful of places makes spacers only good thing about them is they do look sweet and you probably can re-sell them quicker due to bolt pattern to adapt you need spacers anyway so you have to find adapters that bolts to thirdgen bolt pattern and changes to 5x114
the wheels you are looking at are euro design and can find other wheels brands that look alike just look in the BMW/AUDI car scene they like to run similar wheels i was personally looking at MIRO111 wheels i think 2 members have them on thirdgen just search i also was look into http://www.velocitymotoring.com/wheels.html only issue i had with then is they only carry up to 9.5 width and 8.5 up front and alot of the online websites sold as a staggered set i didnt call to see if they would sell non staggered all 9.5 also the MIRO & VMR are 5x120 bolt pattern and you get the style you want there alittle more expensive but i think its worth it
reason why i didnt get it was i just want 10in width all around 10 inch wide allaround just sounded better then 9.5
Car: 92 Camaro Rs.R
hahaha yea, i figure i can mount up a 285 in the rear and a 265 or 275 up front. i already found the adapters, not to expensive either, which is good because im on a tight budget. wouldnt the 20mm offset be better up front? do you know the offset of a 4th gen wheel? i have 4th gen 5spokes right now wth 2inch spacers... i just hate them... and there to small anyway lol i was also thinking that between the 521 and the 530... the 530 is more modern, and its only a half inch difference in width.... not a big deal with a good set of tires. as for the flat problem? i can always put in a different spare .... so the pattern is 4.5 instead of 4.75
Car: 92 Camaro Rs.R
http://www.forgeline.com/products/ce...onversion.html
http://www.forgeline.com/products/co...ries/dp3r.html
i think these would be bad ***.... period...
Engine: 305 to 350
Axle/Gears: 10 Bolt
285 can fit up front 265 or 275 that be quiet a bit of tire stretch up front if your going 9.75 you can fit bigger tire in rear I'm thinking going 295 all around will see I still have room up front ... im not a big fan of tire stretch you should search on google xxr 530 on some imports to get a good idea on tire size and tire stretch seems most are running 225/235 on the 8.75 with large amount of stretch you should be fine with 275 on 8.75 maybe 285 but that might create a unusal tire bulge due to the unusal wheel width ...stretch tire make wheel look smaller and makes wheel to fender gap seem larger it can make or break the look of the car also I think 4th gen wheels are around 40 sum thing for offset that's why you need 2 inch spacer
But you have to do your search on the tire size but it might be ok but have to mount tire on wheel to know for sure
What size are you going to run I think you should run 18x 9.75 all around lol IMO
Engine: 305 to 350
Axle/Gears: 10 Bolt
http://g35driver.com/forums/g35-seda...s-527-a-2.html
Nissan with 18x9.75
With 275 on rear so 285 would be good not much stretch if any
Difference in section width between 265 and 295 is like 1.16inch I believe
Yea spacers not that expensive there out there
The setup should look sweet tho
Look at this also
http://forums.evolutionm.net/evo-x-s...xr-thread.html
Nissan with 18x9.75
Look at this also
Car: 92 Camaro Rs.R
bitchen, yes if i could run a 9.75 up front , i would as long as the wheel didnt look so deep. i want the rears deeper then the front, but who knows , if the 18*8.75 are still out of stock, i might just do 9.75 all the way around,.... for the record, tire streaching is gross and its bad for the wheel and tire... and wont handle at the tires optimum ability.
285 or 295 35 18 tires would look really good with those deep concave wheels, would be really sick on my car... its summit white, 2 inch drop, carbon fiber nascar styled spoiler, black carbon cowl strips on the hood, 20% window tint. carbon t-top rain gutters. ect. and im in the proses of revers cowl inducting the hood into the radiator, and doing a black center of the hood from the windshield down into the scoop... kinda like the new zl1... idk.. lol what do you think??? yes or no
Engine: 305 to 350
Axle/Gears: 10 Bolt
Any recent pics sounds like a lot going I have to see it
I'm going for a real clean simple mean aggressive look I'm thinking of using real carbonfiber for headlight buckets side view mirrors and rear stock spoiler and hood louvers and grill with tinted taillights with artic white paint job nothing much
Car: 92 Camaro Rs.R
head light buckets will be carbon ... and the hood strips will go away once i finish the hood and put the big section in the center of the hood of carbon or matte black, the driving lights are no longer there, and the turn signals up front are gone and are now being built into the headlights, and the openings are going to be ducted to the brakes... its a long ongoing project lol..
Engine: 305 to 350
Axle/Gears: 10 Bolt
Hmmmm IMO I think if you do zl1 hood strip those 2 strips should be removed you have now as imo i dont like zl1 strip would look much more better also zl1 has strip on roof and trunk i believe also ? U plan to do that too Also should paint the light buckets to match strip to give more blance look also you should add to ends of the wing too to make wing look complete
But it's look **** tone better from when you first got it
Engine: 305 to 350
Axle/Gears: 10 Bolt
Car: 92 Camaro Rs.R
yes, when the zl1 strip goes on, the other stripes will be removed, the headlight buckets will be matching whatever i do the hood out of. as far as the spoiler it was done for pur function, and yes it works lol... looks was second, so i still contemplate the end pieces, but i may make them... carbon is really easy if your making flat surfaces. do you think the 530 wheels will go with the euro race look, im actualy building the car for the silver state classic... whenever its finished that is lol, its still got a long way to go
Engine: 305 to 350
Axle/Gears: 10 Bolt
Or extend the ends like this and incorporated into your wing in one piece
http://www.facebook.com/note.php?not...02783129831990
Or add the curved piece to the ends like
http://www.lxforums.com/board/f77/ch...ill-my-293413/
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea 530 would look good for euro look but NASCAR style wing isn't euro lol that's AMERICAN
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea I can't wait to start playing with carbonfiber seems easy and it's not that expensive where did you get your stuff from ?
I'm building mines just for autocrossing it's my daily driver so not going to crazy and keeping it a budget build
Car: 92 Camaro Rs.R
its an American car buddy ;] i just like the sporty euro look lol
the material came from my buddies dad, he braught it home from his work, some space age company who produces it, and if one weav is off it gets tossed out.. so once in a while he will bring home a roll of it ;]
Engine: 305 to 350
Axle/Gears: 10 Bolt
I was just yanking your chain lol your car is going to look pretty slick you will like the wheels it's going to look euro and sporty can't wait to see it finish it's already came along Way and looks a whole lot better like night n day when you getting the wheels ?
Sweet toss a roll over here lol
Car: 92 Camaro Rs.R
hahaha, its kinda up in the air on when i get to order them, i realy need to figure out what size to put up front.i cant decide. hopfully i get to start on making my hood soon too. that would be nice... i wish i had loads of money.... i still have so much to do... finish my lm7,,, cage,,, brakes,,,, ugh lol
