Performance tire and rim size question
Old Nov 23, 2011 | 12:12 PM
Kevin Vandevenne's Avatar
Car: 87 IROC
I'm debating either spending some money to upgrade my current stock 16x8 IROC rims to 17x9.5" C6 replicas and mounting 'so-so to ok' rubber or keeping the stock rims, but putting on "good" tires. Currently running on mismatched no-name store brand tires on the factory rims. Car is not a daily driver, and might see some track time this summer. The rest of the suspension is pretty well covered (koni struts/shocks, UMI camber/caster plates, SFC's, control arms etc etc). I always hear that your tires are the most important part of how well the car will handle, just wondering if there will be a big difference between good 16" rubber opposed to 17" tires on the lower end of the price scale. If I go with the 17" tires I could budget around $500 for a set.
Kevin
Old Nov 23, 2011 | 03:23 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: Performance tire and rim size question
Kevin,
There are no real options available in the 245-50-16 size these days, Tire Rack only has maybe 6 choices in that size, but over 20 choices in the 275-40-17 size. The increase in tire width makes a tremendous difference in how your car will handle - 120mm more rubber under the car (almost 5").
Old Nov 23, 2011 | 06:02 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Originally Posted by paul_huryk
Kevin,
I just bought a set of Falken Ziex 512 tires in 245-50-16. They handle like no other, paid $368 shipped for them from discounttiredirect.com. But like Paul said, there's not a lot of options for 16s anymore. 17s or 18s are where it's at now.
Old Nov 27, 2011 | 06:54 PM
Red 87 GTA's Avatar
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
bfg g-force is a good tire for 16s i have 245s up front and 255s in back i do short circuit racing with them i like them alot
Old Nov 29, 2011 | 05:51 PM
paul_huryk's Avatar
All - check out this GMHTP article I posted today on the Thirgenfbody blog...
http://thirdgenfbody.wordpress.com/2...eptember-2003/
Old Nov 29, 2011 | 06:07 PM
Badazzbird's Avatar
Car: 1987 firebird custom restomod
Engine: 2.8 v6(350 swap comming soon!!!)
Axle/Gears: Stock
Quality of tires are extremely important! It's like the icing on the cake if you will. Don't short change yourself if you can help it.. I spent close to 700 on my continental dws extreme contact all seasons.245-45-17 and 275-40-17 and they are the best tires I've run on my car to date well worth the extra bucks!!!
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
redmaroz
Aug 16, 2015 11:40 PM
knight72
Aug 10, 2015 09:32 PM
