Would 14" berlinetta rims fit on an IROC?
Old Dec 31, 2011 | 12:37 PM
Skyset's Avatar
Car: 86 Iroc-Z
Engine: 305 (TPI)
Axle/Gears: i dunno lolz
Hello all,
Sorry for another stupid thread, but I honestly did a search, and I ended up with mixed answers. Some people say yes, all third gens can use any other third gen rim. However, some people in the search said that 14" Berlinetta rims wouldn't fit on the rear brakes of an IROC. Is this true?
Thank you
Old Dec 31, 2011 | 12:40 PM
Skyset's Avatar
Car: 86 Iroc-Z
Engine: 305 (TPI)
Re: Would 14" berlinetta rims fit on an IROC?
And someone else said that the bolt pattern is different...
Old Dec 31, 2011 | 12:44 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
As far as I know the pattern is the same, 5 x 4.75 inches. The 14's should fit an IROC unless the IROC is equipped with 11.7" rotors and alum PBR calipers (89+), then I assume fitment would be an issue.
JamesC
Old Dec 31, 2011 | 01:00 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Originally Posted by JamesC
As far as I know the pattern is the same. The 14's should fit an IROC unless the IROC is equipped with 11.7" rotors and alum PBR calipers (89+), then I assume fitment would be an issue.
JamesC
what he said
and the bolt pattern never changed.
they will fit front and rear, unless the car has the 1le front brakes, or the 89+ rear pbr's
Old Dec 31, 2011 | 01:03 PM
Skyset's Avatar
Car: 86 Iroc-Z
Engine: 305 (TPI)
Thank you
Frozer!!!
Jan 19, 2024 04:55 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
mustangman65_79
Aug 11, 2015 03:17 PM
