How narrow can i make a 9 inch
Old Jan 3, 2012 | 01:23 PM
dubasracing's Avatar
Car: 1990 camaro
Engine: 5.3 ls based
Transmission: turbo 400 with brake
Axle/Gears: undecided
I am currently getting ready to order a bolt in 9 inch and wanted to know how narrow i can make it without anything rubbing and possibly tuck my current wheels and tires i have centerline warriors that are 15x9 with a 4.5 inch back space with hoosier 29x10x15 slicks and plan on removing inner fender lip on rear. i heard 2 inches is the max on each side? any help or pics would be greatly appreciated thanks guys.
Old Jan 3, 2012 | 01:44 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: How narrow can i make a 9 inch
With those narrow rear wheels/tires, just get one at stock 3rd gen width & your good to go. I have 11"/7"bs/315s on a stock 9-bolt & only "minor" inner fender panel work, no tub of any kind.
Old Jan 3, 2012 | 05:37 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
you have to check clearance from you backing plate to the LCA mounts and the panhard mount, tire clearance to the same points and clearance anywhere else. You should be able to narrow a 3rd gen rear at least 1" each side, which will help your fitment. Anymore than that and you are on your own. Measure many times before you order anything.
Old Jan 3, 2012 | 10:16 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
1.5" per side is typically the max you can get away with.
Street Lethal
Apr 30, 2019 12:14 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Street Lethal
Aug 14, 2015 08:25 PM
Exxon Limited
Aug 9, 2015 08:13 PM
