Aftermarket BMW wheels; Lug nut question
Old Mar 8, 2012 | 03:40 PM
88PontiacT/A's Avatar
Car: 88 T/A. TOTALLED!! (not by me)
Engine: TPI 5.0
Transmission: 700r4 Auto
Axle/Gears: 2.73 posi
Want to use these http://www.tirerack.com/wheels/Wheel...All&sort=Brand
wheels (or something similar) on my 88 T/A. It says to use O.E.M. BMW lug bolts with these. My Question is what lug nuts would I have to use to mount them on MY car? Would I just need some aftermarket (closed end) acorn style nuts with the same degree of taper as the stock ones? Or something else?
thanks,
John C.
Old Mar 8, 2012 | 04:36 PM
Twin_Turbo's Avatar
Re: Aftermarket BMW wheels; Lug nut question
conical 60 degree taper
Old Mar 8, 2012 | 07:11 PM
Engine: TPI 5.0
Cool. Thanks for the info.
Old Mar 8, 2012 | 09:10 PM
Engine: TPI 5.0
Any clearance issues with 17x8 5.24" BS on front, and 18x9 5.83" BS on the rear? Car is all stock / original. Disc front, drum rear brakes...Thinking of running 245-45-17 front tires and 265-40-18 on rear. I may lower the car a bit in the future (and add an adjustable panhard bar) but it is stock ride height for now.
Old Mar 9, 2012 | 01:52 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Fronts will be very close to you ball joint.
Old Mar 9, 2012 | 04:10 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Both have a little.too.much backspacing. Front should be closer to 4.5" and the rear closer to 5.5".
Frozer!!!
Jan 19, 2024 04:55 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Omega
Oct 1, 2015 02:20 PM
redmaroz
Aug 16, 2015 11:40 PM
