18 x 10" rear and 17 x 8" in front need help
Old Mar 29, 2012 | 11:00 AM
sempco09's Avatar
Car: 1989 Camaro
Engine: Modified 350 bored out to about 360
Im going to be buying some new rims but i have some questions. First off and this is my main question, i can get these with custom offset but im upgrading the rear end to a 4th gen rear end with disks, so would it be better to get different offsets for the front and rear (keeping the thirdgen in the front, and asking for 4th gen for rear), or making all 4 wheels with the 4th gen offset and just buying spacers for the front wheels? also if i do the seperate would the wheels still line up for the most part? and lastly would the 18x10s fit "nicely" without having to do any fabrication or would i be better off getting a 9.5" instead? just a heads up suspension will be stock for the time being... i would really appreciate your help
Old Mar 30, 2012 | 10:09 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: 18 x 10" rear and 17 x 8" in front need help
18 x 10 rim is no problem. Mine are 18 x 9.5 with a wide tire, maybe a 285 or 275. Get a fourth gen offset and use spacers on the front. That way you can get any fourth gen wheels when you get bored in a few years. You will, I get new rims every few years, maybe 4. Just check for rubbing and possible body roll.
Old Mar 31, 2012 | 12:29 PM
sempco09's Avatar
Car: 1989 Camaro
Thanks i appreciate the help now just out of curiosity are you running 18x9.5 all the way around?
Old Apr 1, 2012 | 12:19 AM
Tibo's Avatar
Car: 1991 Z28 Vert
17 x 8 with a 245 tire up front
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
MORREALE5
Sep 13, 2015 09:16 PM
