spacers with stock wheels?
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
alright so im just looking to get a wider stance for the time being..going to eventually get new wheels but for now...
is it okay to run spacers on the stock wheels? say, 1.5" in front and 2" rear?
i dont see why it would matter but i want to make sure im not missing anything
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: spacers with stock wheels?
They will bolt together like any other wheels and.spacer, but will that much extra width work? Your wheels.will be outside the wheel well and at your height, that would be a more serious problem than usual..
Engine: 5.7 350 TPI
i just want the wheel to be flush with the fender but im running about 1.5* of camber..is that too much spacer you think?
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
It'll be close, I think 2" adapter would reduce your offset too much. Make sure you measure your clearances beforehand.
Engine: LB9, LB9
You'll have to do a really good fender roll too. And take into account how much suspension movement you have on your compression stroke. What is the exact offsets for your wheels? I could do a few calculations to see how flush you'll be.
Engine: 5.7 350 TPI
yeah im gonna be cutting/rolling the inner fenders..im gonna use this offset calculator in a minute
Engine: LB9, LB9
http://www.willtheyfit.com/index.php...&Submit=Submit
Even 1.5" spacers for the front wheels is pushing it. I compared the stock front GTA wheels (16x8 +0) to my SS wheels (17x9 -1). My SS wheels are completely flush with the fender lips with my 285 tires. I had to do a bit of a fender roll to prevent rubbing even with -1.5* of camber. Although I've heard that Nitto's tend to run narrow.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I think it will look pretty stupid, but you didn't ask my opinion so I will just say that at less than 1.5 inches you'll have a hard time finding adapters. And you you dont want to go past .5 inches for spacers, so if you want the tarantula look then you're in luck. If you want something more reasonable, you'll want to stick with small spacers.
Engine: LB9, LB9
Engine: LB9, LB9
How much camber are you running? If you can find them I'd say get 3/4" adapters (20mm) for the front. And yes, they do exist. I'm running 20mm adapters on my GTI so I can run Corvette Salad Shooters.
And since the rear wheels have a +16 offset you would need 36mm (1.4") adapters to match the fronts, but that's an oddball size that nobody makes. I would get 1.25" adapters to be safe and maybe throw a small slip on spacer to dial in the fitment.
This is a 16x8 with an effective offset of -20mm
pretty much exactly where my SS wheels sat.
I actually have a set of GTA wheels as well. I could throw those on and take some pics to show you what they would look like with 2" spacers.
Engine: 5.7 350 TPI
i would love if you could do that!! id really appreciate it
i refuse to feed the trolls..
Engine: LB9, LB9
Alright I snapped a few pictures with GTA wheels on my car. Now I need to ask. Are you running the wheels in their correct positions (fronts up front and rear out back)?
This is what the 16x8 +0 (fronts) look like on front and rear with 2" spacers
Engine: LB9, LB9
This is what 16x8 +16 (rears) look like with 2" spacers...
Engine: 5.7 350 TPI
nevermind i got it hmmm.....
thinking 1" all around then..what do you guys think??
Car: 86 sport coup
Engine: room for rent looking for ls power
Transmission: t-5
Engine: LB9, LB9
The first pair of pics has a front wheel installed on the front and rear. The second pair of pics features a rear wheel on both front and rear. I did that because it's pretty popular for people to run the rear wheels up front with a spacer and put the front wheels out back, in order to have the bigger lip in the rear. Here's an pic of the whole car.
Engine: 5.7 350 TPI
Engine: LB9, LB9
Personally I think .75" and 1" rear. If its not wide enough you can still throw a small, cheap, slip on spacer to dial it in to where you want it.
Car: 86 sport coup
Transmission: t-5
that looks pretty cool its crazy how different it can make the car look
Engine: 5.7 350 TPI
LT1Formula
Nov 16, 2015 01:13 PM
kah992
Aug 19, 2015 02:55 PM
confused
