newbie with wheel question
Old May 29, 2012 | 07:56 PM
89rsbigblock's Avatar
jsut joined the site as i traded my vega for an 89 rs w/ 454. right now it has keystone classics onit, my question is what year camaro or vette wheels will fit this? thanks for any help
Old May 29, 2012 | 08:14 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: newbie with wheel question
Your first post is wheels? Seriously? Are you still in High School? Not subframe connectors, or a big-brake upgrade? Especially with a 454! Which way you decide to go with brakes will affect wheel choice. Or more likely, spacer thickness. If spacers are even legal in your state, because in Utah they're not.
Old May 30, 2012 | 04:20 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Atilla The Fun brought up a couple of very valid points to be thinking about. These cars flex alot so subframe connectors should be high on your list of add ons. Especially with a big block. The stock rear drums aren't much to speak of either. With more power comes a responsibility to make sure it can stop good also.
As for what can fit? You can fit any 2nd gen or 3rd gen F body wheel directly. 4th gen wheels with a spacer that may or may not be legal for you. Most of the 5 bolt rear wheel drive GM car wheels will fit but may require a spacer. It may serve you well to think of what you might do for a brake upgrade and that can help dictate what diameter wheel you can use.
Use the search feature to try to learn more about this.
Good Luck
Old May 31, 2012 | 12:48 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Welcome to the site ,
Here are a few wheels you can look at. It will show you allot of the options out there.
Here's the link = https://www.thirdgen.org/forums/whee...termarket.html
Old May 31, 2012 | 12:55 PM
thanks for some of the input guys. i got a set of iroc wheels given to me so the wheel search is complete.. as far as other upgrades i just got the car and have not looked at brakes yet, but it does have frame connectors.
Old May 31, 2012 | 02:09 PM
91phoenix's Avatar
Old May 31, 2012 | 02:14 PM
91phoenix's Avatar
Good deal on the IROC wheels. With the frame connectors already you are in much better shape. We all understand not being able to do everything at one time but we do want you to have a safe dependable car too.
If the wheels need cleaning or polishing there is very good info on it in the detailing and appearance section.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
R3500
Aug 24, 2015 09:05 AM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
