wheel fitment
Old Jun 24, 2012 | 04:05 AM
J-RoKz's Avatar
Car: 1989 iRoC-Z, 1991 Rs
Engine: L98, L03,Lsx swap soon
Axle/Gears: G92 3.27,10 bolt 3.23
wheel fitment
im currently swapping out my c6 z51 brake for the c6 z06 brake and was wondering if the 18x9.5 c5 z06 wheels would fit without hitting the spoke as i have seen c5 corvette with the c6 z06 brakes running 18x10.5 c5 z06 wheels in the front and fitting tight i know i would have to run spacers what do you guys recommend? im not worried for the rear as iam running the 4th gen rearend any help would be appreciated
Old Jun 24, 2012 | 07:13 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: wheel fitment
There are a couple on here with 295/35R18x10.5s on the front, it can be done. I'd be doing it if I wasn't working on AWD.
Old Jun 30, 2012 | 04:02 AM
J-RoKz's Avatar
Re: wheel fitment
do you happen to know what kinda spacer they using and are they rubbin and are they lowered or stock height i have yet to see a 3rd gen with c5 wheels on c6 zo6 brakes
Old Jun 30, 2012 | 07:34 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: wheel fitment
The 9.5 wide wheels should fit the bakes if they are 18". You will be using a spacer, probably 2" or so and that will provide plenty of clearance to the spokes.
Old Aug 28, 2012 | 05:54 AM
J-RoKz's Avatar
Re: wheel fitment
yes i plan on runnig 18x9.5 in the front with prob 2inch spacer and 18x10.5 in the rear im alreasing runng a ls1 rear end so no spacer needed for the rear another thing that concerns me i have eibach sportline spring do you think ill have rubbin issues? What wdth tires you recommend?
z 28 jari
Sep 14, 2021 10:03 PM
Fronzizzle
Feb 9, 2017 09:31 AM
Chad Speier
Sep 24, 2015 12:32 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
