What size spacer for +40 offset wheels?
Old Aug 7, 2012 | 09:28 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
looking at a set of wheels that have a +40 offset and plan to run 245 or 255 will 2" spacers work?
Old Aug 7, 2012 | 09:41 PM
Z28Johnny's Avatar
Re: What size spacer for +40 offset wheels?
IROC wheels are 0 on front and like 13 on rear. I did 0 on front and back and they are just about even with the edge of the fenders. I think 2" is the normal adapter for any corvette or 4th gen rims.
Old Aug 7, 2012 | 10:35 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Maybe by the year 3000, we'll get to stop having to post this page over & over. BTW...38 is close enough to 40.
http://www.skulte.com/adapterfaq.html
Old Aug 8, 2012 | 10:34 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Depends on the wheels - 8" wheels will require a different spacer than 9.5" ones with that offset...
Old Aug 23, 2012 | 03:16 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Old Aug 25, 2012 | 01:50 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
The offset is directly related to the width of the wheel.
Amillionoh7
May 24, 2020 08:01 AM
toronto formula
Nov 10, 2015 06:17 AM
kah992
Aug 19, 2015 02:55 PM
knight72
Aug 10, 2015 09:32 PM
