shaved back pad on ZR1 17x11's
Old Nov 17, 2012 | 04:56 PM
mr305's Avatar
Car: 91' RS
Engine: 310 C.I.D. + n2o
Axle/Gears: built 10 bolt 3.73's
I recently got around to installing my wheel since i just got the car running, they are staggered C4 ZR1's (17x11--17x9.5).
i cut the bump stop and they dont rub on the inside but if it bottoms out hard enough it will hit the the outside lip of the fender well.
So my question is i need to bring them in maybe 1/4"--3/8" on each side how much can i safely have the back pad machined? Can i get away with the 3/8" i have a 4th gen rear end and no spacers so the only way to move them in is to machine the back pad does anyone have any experience with this??
Old Nov 17, 2012 | 05:08 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: shaved back pad on ZR1 17x11's
You can roll the fender lips in so that will gain you some room & reduce the amount of hub you'd hafta shave. I assume that you mean the hub of the wheel?
Old Nov 17, 2012 | 08:31 PM
mr305's Avatar
Car: 91' RS
I rolled the fenders already but its just a bit off I'm just wondering if I can safely shave off enough to tuck them I asked the machinist but be said they couldnt be shaved down but from what I heard there is an acceptable amount that can be shaved off
Here are some pics of some test fitting I did with the rear springs removed
Attached Thumbnails shaved back pad on ZR1 17x11's-2012-11-16-14.00.35.jpg   shaved back pad on ZR1 17x11's-2012-11-16-14.00.48.jpg   shaved back pad on ZR1 17x11's-resizedimage951352768922218.jpg
Old Nov 17, 2012 | 08:40 PM
Car: GTA
No shop with tell you that they can shave a wheel due to possible liability if the wheel fails. I've been down this route before with wheel manufacturers & machine. And I wanted to shave the same 1/4" to 3/8" max.
If you can talk them into doing it, you'll likely to either be asked to sign a waiver and/or the receipt will state that it was not recommended & that the company assumes no liability in any case of failure.
Old Nov 17, 2012 | 09:04 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Its generally a bad idea to machine the pad on the wheel, if you look in the lug seats, you can see how thick the lug openinng is after the taper and its generally not thick enough to be able to remove much material. I would advise against doing it
Old Nov 17, 2012 | 09:29 PM
mr305's Avatar
Car: 91' RS
ill have to measure the thickness i may just end up leaving it alone if its not alot of material in there
Old Nov 18, 2012 | 01:23 AM
Homer23's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: T-56 w/hurst short throw
Axle/Gears: unknown
You may just have to get mini-tubs.
Old Nov 18, 2012 | 01:38 AM
Mailman818's Avatar
Car: 89 firebird bone stock for now
Engine: 2.8L V6
Axle/Gears: B.W 9Bolt 3.27 Posi
Fender flares??
Old Nov 18, 2012 | 02:25 AM
mr305's Avatar
Car: 91' RS
No this will be driven a lot I'm not gonna get drastic with it it'll be fine the way it is I guess its more of a personal preference to have them tuck at its present ride height rubbin issues will be minimal I'm hoping lol ill do some measurement see how much material I'm working with I figured someone had done this already
If I have them shaved ill post pics of final fitment
Old Dec 3, 2012 | 11:10 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Roll 'em flat or even do a slight pull. You can work those fenders a lot more. The lips still roll inwards.
Old Dec 4, 2012 | 02:45 AM
mr305's Avatar
Car: 91' RS
After I rolled the lips and lowered it more I took it out for a spin and no rubbing anywhere I still need an adjustable panhard bar to center everything but besides that its all too good go!
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
madsv1000
Aug 20, 2015 06:45 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
