91 Camaro steering problems.
Old Nov 18, 2012 | 08:54 PM
CMFD2712's Avatar
Ok so new to DIY, so need a little advice
Bought the camaro about a month ago, within a week the steering went from perfect to no assitance. I could only get power in anything higher than idle rpms. Replaced the power steering pump. Everything was perfect again. Drove the car all day today ran fine, on my way home, I completely lost steering, barely made it into a parking lot.
Let it sit while I looked things over, everything looked fine no leaks, reservoir was full, belt was tight. Had the gf try and turn the wheel back and forth. I could see the column turning with the wheel past the universal. So, I'm at a loss I got some movment back after turning the steering wheel from left to right a couple of times. Nothing like it was the first time the pump went bad, I can't get assitance at any rpm. Barely got the car home, where should I go from here as far as diagnosing the problem?
FYI, on my phone so it might be a minute before I can respond.
Old Nov 18, 2012 | 11:05 PM
spicyskater's Avatar
Car: 1987 camaro Z28
Transmission: manual
Re: 91 Camaro steering problems.
well u need steering box....there is valve in the steering box that changes the oil flow depending if u turn left ort right...so i guess yours went bad...
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
backtothe80s
Sep 5, 2015 12:39 AM
Fronzizzle
Aug 9, 2015 01:15 PM
