Wider tire, less traction!?
Car: 1988 iroc
Engine: 350 tpi
Transmission: t-5
Axle/Gears: stock
So I recently went from stock iroc 16 inch 245 wheels and tires to 07 vette rims that are 18x245 up front and 19x285 in the rear. I've got spacers, lowering springs, hotchkis rear sway bar and LCA's with LCA relocation brackets. Both the old iroc tires and the corvette tires are worn, (the corvette tires were used before I bought them) and for some reason I get significantly less traction with the corvette rims. Tread is about 50% compared to the iroc tires that had about 10% tread left. Any reason you could think of why this would happen?
1 Post
Car: 91 Camaro RS
Engine: GM PP crate 350
Axle/Gears: 3:42 spooled 10 bolt
Re: Wider tire, less traction!?
no, as pontiac would say, wider is better. could be the tread compound possibly making it not hook up and ground temperature.. other than that idk. i never have a issue going wider in my experience, except with a bad tire brand or something. as far as tires go, have u tried going wider than what u currently got? if not then, i may suggest it.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
If the new tires are a harder compound, it can reduce traction. Width isn't everything. And the shorter sidewalls allow the sidewall to flex less, again reducing traction ability (ever watched a slo motion video of a wrinkle wall drag slick upon launch?).
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
i assume you dont base this on the fact it snowed here in NJ today....
tire compound and tread have a lot to do with this, the other tires could be all season and work better when its cold, if the vette wheels have hi performance summer tires on them, they will be about worthless right now int he cold.
what tires were on both wheels?
Car: 1988 iroc
Engine: 350 tpi
Transmission: t-5
Axle/Gears: stock
yea, the f1's are summer tires, they are not going to be good in the cold, they will be too hard in the cold. Depending on which f1's they are, you could even crack them.
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
There a couple different Goodyear Eagle F1's...
Car: 1988 iroc
Engine: 350 tpi
Transmission: t-5
Axle/Gears: stock
Engine: LB9, LB9
Tell us the tire make and model...
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
