The most basic thing to understand when ordering wheels w/ different offsets is . . .
Old Nov 28, 2012 | 06:52 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
That the stock backspacing for our cars was 4.5"F and 5.5"R; and that whatever offset you order, you want to get a spacer/adapters that maintains those numbers???
Or is there wiggle room to how much more or less backspacing will work on our cars, eg, if someone wants a flush look they may go with 5"F and 6"R (but they may rub up front during full lock?).
I'm just trying to understand the math here, as I'm looking at some 8.5"F (30 offset) and 9.5"R (35 offset) for my car. They're made for BMWs, so I would have to get an adapter/spacer anyways to adjust for the slight difference in lug pattern.
Old Nov 28, 2012 | 07:17 PM
Twin_Turbo's Avatar
Re: The most basic thing to understand when ordering wheels w/ different offsets is .
3 series fitment really put the rims tucked in there I myself hate it. You can go to ET20 or even 15 and it'll look a ton better. 5 series fitment. I have 8.5 & 9.5 ET15s on my car and it's near perfect and the front are even further out than stock because of a C5 brake upgrade. I run them bolt on with quality hubcentric rings and never ever had a problem and I have put a lot of miles on the car with several BMW wheel sets. In fact, only 350 miles to go and my 88 is "new" again LOL
you decide what looks better (the M6s are only 8J wide and 18"..they just had to go)
3 series fitment ET 35
5 series ET15
Old Nov 28, 2012 | 08:35 PM
Car: 91 RS
Engine: 350 TBI
5 series ET15
What spacers were used in those examples? With some 1" spacers up front and some 1.5" in the rear it should push these out enough right?
If I may, where did you get your hubcentric rings at? (w/o spacers?)
Thanks for the help brother.
Old Nov 28, 2012 | 08:38 PM
Twin_Turbo's Avatar
none, all direct bolt on. You can buy the hubcentric rings on ebay and specialized hubcentric stores http://www.hubcentric-rings.com
Old Nov 29, 2012 | 10:32 AM
Car: 91 RS
Engine: 350 TBI
So with these BMW wheels that I'm looking at:
F: 19 x 8.5 (+30)
R: 19 x 9.5 (+35)
I should pick up some adapters from http://www.motorsport-tech.com/ that are 1" in the front and 1 1/4" in the rear? Of course the adapters would adjust the bolt pattern.
And lastly, looking at 245/35 up front; and 285/35 for the rear.
Thanks against for everything.
Old Nov 29, 2012 | 01:31 PM
Twin_Turbo's Avatar
Check if the wheels are available for a 5er. The 3s will work without spacers.
I run 265 & 295s
Old Nov 29, 2012 | 02:50 PM
Car: 91 RS
Engine: 350 TBI
I run 265 & 295s
They don't make them in another ET unless I change the width. I know they'll work without spacers (as your pic shows), but I think they'll look even better with the 1" and 1 1/4" adapters. Plus, up front it should help clear the suspension bits better, even though I would think that the 19" diameter would help in the department too.
Thoughts? . . . good on the adapter sizes I'm listing?
As for the tires, I saw this thread which is why I'm going with the same sizes: https://www.thirdgen.org/forums/whee...axis-hiro.html
Old Nov 30, 2012 | 09:44 AM
Car: 91 RS
Engine: 350 TBI
Can anybody else back up my math/assumptions? The company's Cyber Week specials end today and it could save me some coin.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
ezobens
Aug 19, 2015 10:29 PM
