Max Slick Width
Old Dec 1, 2012 | 07:36 AM
jims85x2's Avatar
Max Slick Width
My 85 is strictly a drag car. It has not been back-halfed or had really any work done on the suspension except air bags. I'm running 15 inch wheels with 10 inch slicks, not sure the diameter. I have swapped engines and the new engine has about 150 more hp than the old one. I need to be able to put on bigger tires but I don't know how big I can go. If anybody has any ideas, I would appreciate it.
Old Dec 1, 2012 | 08:39 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Max Slick Width
That's about it without inner wheel well work. That said, people run really really fast on smaller drag radilas, so you might consider tuning the suspension over just installing a larger tire.
Old Dec 1, 2012 | 05:07 PM
project89's Avatar
Re: Max Slick Width
i managed to get a 28x10.5 wide on my car using a weld draglite 15x10 rim i forget the backspace though , i had to use 1/4 inch spacers but other then that just a lol hammering of the inner wheel well and bumpstop and some slight triming in the front of the iner fender and they never rubbed
i have pics somewere if u want thewm
Old Dec 6, 2012 | 05:50 AM
jims85x2's Avatar
Re: Max Slick Width
I would like to see some pics. Forgot to mention this car has a 9" Ford rear end. I believe the axle housing has been narrowed. my email is jreiley@frontiernet.net
Thanks.
Old Dec 6, 2012 | 09:25 AM
AutoRoc's Avatar
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
Re: Max Slick Width
A friend had 29.5x10.5(measures 29.8" tall)ET Drags on his 92 RS but it took cutting the bumpstops out and some hammering. Never ran it, didn't look safe at all. I'd stick with 28x10.5's myself. People put 2000+hp to that tire.
Old Dec 6, 2012 | 02:08 PM
86iroc2try's Avatar
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
Re: Max Slick Width
As stated above...
Use a 28" slick...hammer the front of wheel well and take out bump stops...change the gear if you need to.
With more power...you may be running higher rpms with the new motor...so keep that in mind with your combo.
Linson
Oct 24, 2025 02:00 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Gordonr1973
Sep 29, 2015 11:59 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Brian Anderson
Wheels and Tires
Sep 12, 2015 06:12 PM
