Torq Thrust II's backspace question
Car: 1989 IROC-Z
Axle/Gears: 2.77
I have a Stock 1987 Iroc-Z that I would like to put TT2's on but im not too sure on the backspacing. Ive been searching on here but honestly im confused beyond belief already. I just need a definite answer before I order. I want to put on 18x8 on the front and 18x9.5 on the rear. Just not sure on the backspacing. What backspace can I run on the front and rear so that it will fit perfect without rubbing or having to mod anything? Any help is appreciated
Car: 1986 IROC-Z
Axle/Gears: 4:10
Re: Torq Thrust II's backspace question
Welcome to the forum. There are some sticky threads on top that have some great info. Personally, you'd want to measure for yourself rather than take somebody's word on it. These cars are old and who knows that previous owners have done in the past.
Check out this link.
https://www.rsracing.com/tech-wheel.html#backspace
Car: 88 Trans Am Hardtop
Engine: 350 L98
Transmission: Stock 700R4
Axle/Gears: 3.27 Aussie 9
Do 18x9.5 all around with 5.5 inch back spacing.
These are 17x9.5 all around with 5.5bs
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
18x8 with 4.5 backspacing for the front and 18x9.5 with 5.5 backspacing on the rear will fit perfect with no mods or rubbing.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Please go 9.5" on all 4 corners please - your car will thank you for it...
Engine: 350 L98
LT1Formula
Nov 16, 2015 01:13 PM
