Wheel and tire size backspacing
Old Jan 16, 2013 | 08:47 AM
dynodave's Avatar
Car: 1991 Z28
Engine: L98 350 TPI
I just bought a set of wheels for my 91 Z28. The rears are 9 1/2 x 18 with 275/40/18 tires. Front is 18x8 with 245/40/18 The rear is a 5" backspacing. Im concerned that the tires are too far out and will rub when I lower car. No issues with stock suspension. Have I chosen wrong backspacing or wrong tire. Most wheel/ tire pkgs I've looked at have this wheel but a 275/35/18 tire. Any help will e greatly appreciated...
Old Jan 16, 2013 | 06:19 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Wheel and tire size backspacing
The wheels should have had a little more BS in the rear, but should still work with a lowered car. So long as you have good shocks in the rear all should be fine.
Old Jan 17, 2013 | 04:15 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
As 86TA said, the rears would fit better with more backspacking. 9.5 width rear wheels with 5.5in backspacing fit perfect on my car. With only 5in backspacing your tires will probably not clear the fender lip, you may have to roll them.
Old Jan 17, 2013 | 09:26 AM
dynodave's Avatar
Car: 1991 Z28
Engine: L98 350 TPI
Thanks, yeah I think I'm going to have to order two new wheels. It works now but lowering springs are on the way and I can't see a way they won't hit. My bad for not doing enough research...
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
overdriv
Aug 20, 2015 03:52 PM
forstral
Aug 19, 2015 03:20 PM
