5/8 studs and wheels that will fit them.
Old Feb 22, 2013 | 03:15 PM
sittincamaro's Avatar
Engine: IVTEC 2.4L aka SBC
Transmission: auto
ive tried doing several searching but it keep coming up with 5/8 wheel spacers or 1 5/8 head tube sizing. I bought a rear that has 5/8 wheel studs and im trying to figure out what wheels will fit them? bolt pattern is 5 x4.75. i had to redrill my rotors to get them to fit but because with the larger studs the pattern is just slightly too large for the rotors to slip on. will have the same problem with most wheels? is there a list that shows what wheels are compatible 5/8 studs?? sorry if this is basic i have had to buy a new set of wheels before. these wheel studs and ls1 brake up grade have my head spinning a bit. i have pbr's in the rear and ls1 brakes upfront btw.
Old Feb 22, 2013 | 06:44 PM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
Re: 5/8 studs and wheels that will fit them.
weld rts will take 5/8 studs. i have the 15x10 6.5bs
Old Feb 22, 2013 | 06:55 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
It's a tight fit, but CTW Motorsports' wheels have 5/8" openings for the studs - problem is getting a small diameter lugnut to fit in the recess for the lugs...
Old Feb 23, 2013 | 04:18 PM
Transmission: auto
I really like the RTS wheels but i dont think my ls1 front brakes will fit with a 15 inch wheel (id like to have 15's in the front and rear) unless i run a 3.5in wide rim. i want to be able to steer and stop safely on the street so i dont want to go that narrow with the front wheels. no sense in doing the brake upgrade is there isnt enough rubber on the road to take advantage of them.The RTS dont come in 16 in and the price of the 17's is through the roof.
Old Apr 10, 2013 | 05:14 PM
Transmission: auto
loneroad - i went with the rts. what lug nights are you using? the moroso nuts have wont fit on the wheels.
Old Apr 11, 2013 | 04:11 PM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
i bought my fine thread studs from coleman racing. The spacers and lug nuts i got from jegs.
Old Apr 11, 2013 | 08:53 PM
RoadHammer's Avatar
Car: 1991 Camaro Z28
Axle/Gears: stock
If you have the financial means, Forgeline will make custom set of wheels to fit 5/8" drive studs. I have a set of 18" Forgelines made to fit such an arrangement.
customblackbird
Aug 15, 2021 10:16 PM
Street Lethal
Apr 30, 2019 12:14 PM
hectre13
Aug 26, 2015 08:17 AM
kah992
Aug 19, 2015 02:55 PM
