Bump stop ?'s
Old Feb 25, 2013 | 01:32 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Bump stop ?'s
So, if you cut the bump stops off for clearance, what do you do to insure the axle doesn't bottom out on the frame rail?
Old Mar 9, 2013 | 10:05 PM
watajob's Avatar
Car: 92 T/A 'vert
Re: Bump stop ?'s
Any one?
Old Mar 10, 2013 | 01:47 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Bump stop ?'s
You'd have to have a lot of weight back there to even touch them. Think the tires hit the wheel wells before the axle hits the frame with them removed
Old Mar 10, 2013 | 04:20 AM
watajob's Avatar
Car: 92 T/A 'vert
Re: Bump stop ?'s
I know one dry rotted off on my Formy with stock rear tire/wheel combo and it was banging all the way home from Indiana. I'll probably rub up against the ASC "massaged" wheelwell on the 'vert. Just wondering if there's a way to prevent it.
Ed1LE
Sep 30, 2018 09:14 AM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
sjorgens
Oct 1, 2015 07:54 PM
Luigytico09
Oct 1, 2015 08:46 AM
1HotZ28&SS
Sep 28, 2015 08:58 PM
