18x9.5 with 40 offset, 275/35F & 285/35R w 1.25" spacers?
Old Mar 7, 2013 | 11:49 AM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Sound right to have no issues?
Old Mar 8, 2013 | 09:27 AM
Car: 91 RS
Engine: 350 TBI
Re: 18x9.5 with 40 offset, 275/35F & 285/35R w 1.25" spacers?
Yes . . . no . . . should I just shoot myself in the head?
Old Mar 8, 2013 | 09:44 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Sounds good to me, although 1.5 may be better for fronts, 1.25 should tuck them in more and may not give full clearance on lock to lock turning. Rears should be fine with 1.25
Old Mar 8, 2013 | 10:17 AM
Car: 91 RS
Engine: 350 TBI
Well there is a Baer kit on the front that I was trying to compensate for.
Old Mar 8, 2013 | 10:25 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Ok then you should be ok if that moved brakes out 1/3 to 1/2 inch. Still alittle tight but may work. I have 8.5" wide fronts but 56mm offset so backspacing is similar to you. I run c5 brakes and a 1.7" adapter with 255 tires and clears well. Sits in nice. Full lock doesnt rub unless suspension travels like in a bump situation and i am lowered in front pretty low.
275's sitting in closer will likely rub abit more. 1.5" spacer likely be a better idea if you dont have adapters yet
Old Mar 8, 2013 | 10:30 AM
Car: 91 RS
Engine: 350 TBI
No, I don't have them yet. I may go with the 1.5" as you suggest. Is the best place to them from motorsport-tech.com? Skulte is long gone right . . .
Old Mar 8, 2013 | 11:47 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
There are a few adapter places out now. I havent bought them in 5 years so i have no clue who is the go to shop now. Skulte has been gone for awhile
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
