Crazy rubbing upfront, 17x9, could use help
I have C5 brakes and 2.5" spacers, the wheels I have are presumably stock 17x9 SS wheels (from LS1 cars) (I am 99% sure they are the stock wheels, not some repro model with different offset) and tires are 275/40/17
it seems outside front edge of the tires rubs on inner fender liner, I've pushed back and screwed in the liner as much as I can, that's not it, it's bad enough that it wore a hole right through it :/
what's the correct spacer size? I suspect mine are too "thick" and the wheel actually sticks out slightly past fender as well which further makes me lean toward that conclusion.
if someone can tell me what to measure to figure this out I'm capable of that, but I'm not sure where to start
thank you in advance for any help I may get here.
Re: Crazy rubbing upfront, 17x9, could use help
hmm I may have answered my own question by finding this: http://www.skulte.com/adapterfaq.html , isn't that how it always is? lol
2" spacer the norm then I guess and I'm off by .5 which is a lot
guess I'll see if I can trade someone my 2.5 for their 2
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Your going to want around zero offset, or 5" of bs with those wheels. Measure the backspacing and get the proper spacer/adapter. Most likely you will need a 2" spacer.
I'm searching now, but who sells them now? it seems skulte.com is throwing an error..
Car: 1971 Camaro
Engine: 427
Doesn't the c5 brakes add about 3/8" as well?
I would think 1.5"-2" spacer would be good.
Car: 86 Trans Am
Only adds .22 or so. Won't matter really, but if you wanted to could use 1/4 less frfont spacer
Pac J
May 17, 2020 10:44 AM
MrPackstin
Oct 25, 2017 08:09 PM
