New Wheels Help.
Old Apr 2, 2013 | 09:26 AM
RelentlessRS's Avatar
Car: '91 Camaro RS
Engine: 5.7 350
Transmission: 700 R4
New Wheels Help.
So I drive a 91' Camaro RS with the stock wheels. I every place I call gives me different numbers. For rear wheel backspacing do I go with 4.5" on my new wheels? 16 X 8 wheels.
Thank you.
And heres my latest pic of the rebuild!
Old Apr 2, 2013 | 10:15 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: New Wheels Help.
Tell us what wheel size and width you want... Makes all the difference.
Old Apr 2, 2013 | 10:21 AM
Car: '91 Camaro RS
Engine: 5.7 350
I'm going with 16 X 8
Old Apr 2, 2013 | 11:04 AM
Rickey_85TA's Avatar
Car: 1985 Pontiac Trans Am
Engine: 305 (5.0L) TPI
Axle/Gears: 9 Bolt Borg Warner Posi-traction
4.5" backspacing should work fine. You can't go higher than 4.8".
Personally, I would get the same offset/backspacing for all 4 wheels so you can rotate your tires.
Check out this link for more info
http://www.skulte.com/adapterfaq.html
I know if you put the rear wheels up front, they hit the tie rods. According to skulte.com the rears are 4.9" backspacing.
Old Apr 2, 2013 | 11:27 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
No, rear 16x8 factory wheels have 5.125" of bs, fronts have 4.5. Skulte's numbers are not quite correct
That said, yes you can use 4.5 on the front and rear with no problems.
Nick McCardle
Sep 10, 2015 08:36 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
