zq8 center cap question
Car: 1986 z28
Axle/Gears: ?
i just spent some time refinishing my 15" z28 wheels from what i understand the 15" z28 wheels are the same back space all around. now my question is has anyone tried the zq8 center caps on this wheel? somewhere on the net i found a pic of them on there and for the life of me i cant find it now. theses centers are not cheap i would rather not buy them just to find out they don't work.help please
Car: 1986 z28
Axle/Gears: ?
Re: zq8 center cap question
this is what i want to do has anyone tried this or is this a photo chop type of thing
http://i582.photobucket.com/albums/s...lzq8center.jpg
I am also curious if there is a trick to this. I have the center caps with the rimmed lug nut caps but it would appear my lug nuts (which are factory 1999 4x4 blazer acorns) are not quite long enough for the lug nut cap to bite onto the threads on the lug nut. Are there certain lug nuts you need or am I just missing something.
Car: 1986 z28
Axle/Gears: ?
I used the stock Camaro lug nuts that have the external threads.on the back side of your center caps you will see small tabs that hold the cap off the surface of the wheel I cut those off after that they will sit close enough to the wheel to allow the black caps to screw onto your lugnuts
Car: `86 SS / `87 SS
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
ambainb
Apr 25, 2016 09:21 PM
kah992
Aug 19, 2015 02:55 PM
