Bigger Rear Wheels/Tires
Old May 21, 2013 | 05:35 PM
kevingrealish's Avatar
Car: 84 Z28
Engine: 350 V8
Transmission: 5 speed
I'm finally gonna start putting my 84 z28 back together (wrecked 3 years ago). I want to put bigger wheels and tires on the rear and probably keep 15s on the front. Please reply with any suggestions, recommendations, etc. And Pics would be great!
Old May 21, 2013 | 06:00 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Bigger Rear Wheels/Tires
15x10s are the largest you can fit before having to do major surgery.
5.5" backspacing will fit no problems with a hammer in a few spots
6.5" backspacing which most people use takes some cutting and hammering (shaving bump stops some wheel well cuttting)
6.5" is is what most people like because the 8" wide rims are 4.5" backspacing so 10" wide rim with 6.5" backspacing will have the same spacing on the outside of the rim.
Various people will say 5.5" backspacing will stick out of the fender but it doesn't with the proper tire. It does bring the tire pretty close to the lip.
http://www.spohn.net/support/questio...difications%3F
Old May 22, 2013 | 12:56 PM
Car: 84 Z28
Engine: 350 V8
Thanks for the info fireturd. Any idea how I can see some pictures of camaros with these different setups? I've googled a few different things but haven't had much luck
Old May 22, 2013 | 01:02 PM
Engine: 383 SBC
https://www.thirdgen.org/forums/whee...ures-29x9.html
Old May 22, 2013 | 07:13 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
If your going to stay with 15s and its primarily a street car I would not go any larger than 235/60r15 front on a 15x7in wheel and 255/60r15 rear on a 15x8in wheel.That set up will give you a nice staggered look with a slight rake.7in.wide front wheels give you just enough dish and the 8in. wide rear wheel gives you a nice deep dish. The reason I prefer that combo for primarily a street car is IMO the larger, taller 275/60r15 look like your ready to launch a 500hp car at the track and there's nothing wrong with that if that's what your looking for , and then there's the 295/50r15s that will not tuck without major well work and are total overkill "again" for primarily a street car. Here's a link that shows what I'm talking about. =
https://www.thirdgen.org/forums/whee...er-cobras.html
Old May 22, 2013 | 07:31 PM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Right now I'm running 235/60s on 8s on the rear, don't know the backspace or offset, but the wheels themselves aren't protruding. The tires are on the verge, but have right at 3" of clearance from the bulge above the bump stops.
So with the right backspace a 10 should tuck.
Old May 22, 2013 | 11:04 PM
Engine: TBI,5.0
It kinda sucks but there are really only 2 choices when it comes to 15in.wheels that fit your request. There's the 255/60r15 on a 8in. wheel (what I have) or the 275/60r15s on a 10in. wheel or larger tires with tub work.
(some have squeezed a 275 on 8in. wheels)
Here's a link showing some of the cars with 275/60r15s
http://images.search.yahoo.com/searc...orr-top&norw=1
Warlocksirix
Sep 3, 2015 12:26 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Thornburg
Aug 27, 2015 08:33 PM
Keith5
Aug 27, 2015 04:37 PM
lt1z350
Aug 23, 2015 08:33 PM
