your ideal rim/slick size?
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I'm going to drop some $$ on new rims and slicks for my TTA, just wondering what you would buy if you were to do the same? I was thinking 8" rim with 4.5" backspacing and a 28 x 9.5" slick?
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: your ideal rim/slick size?
Question for you - do you have a set of wheels already you want to match, want a new set, just a pair? Also - is this car street driven mostly, or only a track car?
Car: 89 GTA
Axle/Gears: 4.10
I drive the car a few times a month max on the street, but I have a new set of BFG sports on the original rims so I don't want to buy drag radials to use for both street and track. I have a solid spool rear end so I only get about 1,000 miles of street driving on drag radials.
I haven't used DR's much on the track, what don't you like about slicks?
I'm able to cut 1.6 60' times with slicks I had, but they are worn out and 10yrs old now. I still run the stock TQ arm (hard to find TTA aftermarket), only rear mods I've done is panhard bar and yellow bilsteins.
The ultra floaty and wandering feeling of the slicks at high speeds honestly scares me - especially in a car that is ultra stable on street tires.
Have you looked into the trans x-member mounted TQ arms (if they fit) your car? Obviously you aren't going to want to hack up a TTA with some oddball ladder bar setup or anything. I know Spohn makes an arm that can be used with 200R4 transmissions....
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
