Polishing Rims
Old 06-13-2013, 10:37 PM
dmwracing42's Avatar
Car: 1984 Trans Am
Engine: 355
Axle/Gears: 10 Bolt, Torsen Diff, 3.73's
Polishing Rims
Hey all, so the aluminum rims on my '84 are not fantastic right now. I'd like to polish them using 400, 800, and then wet sand 1200 sand paper, but I know there's paint on them right now. Can I sand through the paint, or should I strip it first? Any other ideas area appreciated.
Old 06-14-2013, 12:13 AM
cavazos31's Avatar
Car: 1988 camaro sports coupe
Engine: Fast Burn 385
Axle/Gears: 9 bolt w/ 3.27 gears
Re: Polishing Rims
it will take forever to sand through paint with 400grit. strip them or use a more agressive grit paper. i'd use a brush on aircraft stripper. what kind of wheels? follow the wheel polishing sticky on the "auto appearance and detailing" board and use polishing compounds on buffing wheels for the best results.
Old 06-14-2013, 05:19 AM
Car: 1984 Trans Am
Engine: 355
Re: Polishing Rims
They're the slotted aluminum wheels.
Thanks!
Old 06-14-2013, 10:29 AM
cavazos31's Avatar
Re: Polishing Rims
those have a pretty flat surface, you can save yourself a lot of time if you have a small hand/palm sander. a 1/4 sheet sander is the most useful tool along with a electric drill. the 'buffing vs polishing' link, in the polishing your wheels thread, has the most useful info. start with a low grit and work your way up. i'd suggest sanding to 600 before polishing with compounds on buffing wheels. the time you put into removing imperfections prior to polishing with compounds, determines the clarity of your finish. you can get them looking close to chrome if you want to...just make sure to sand well enough or youll get a cloudy finish. again, a 1/4 sheet handsander is highly recommended if you can spare the few dollars. even a cheapo harbor freight sander should work for such a small job.
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
BrianChevy
Wheels and Tires
08-08-2019 02:16 PM
Bubbajones_ya
10-25-2015 08:01 PM
bigjay89gta
10-15-2015 08:04 AM
dbrochard
Exterior Parts for Sale
10-10-2015 01:03 PM
Quick Reply: Polishing Rims
