Tallest rear tire?
Old Aug 1, 2013 | 05:32 PM
ssrogers's Avatar
Tallest rear tire?
I have a '92 Camaro RS that I want to put a LM7 and the Silverado 5-spd (NV3500) with 17/18 corvette wagon wheels. The problem is I have 3.73s. I don't want to put my 3.23s back in. The first gear will be So low and fifth will be even more rpms than my 700R4. I would rather just run a slightly taller tire in the rear. So, not that I'm going to run the tallest tire possible but just so I know my range, does any body know what the tallest 275 you can fit in the stock fender. I will roll the lip.
Thank you,
Steven
Old Aug 1, 2013 | 07:19 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: Tallest rear tire?
Thank you,
Steven
A 275-40-18 tire is a readily available size and is 1" taller than a stock 245-50-16 one (about 4%). That was the OEM size on the rear of the C5 vettes...
Old Aug 1, 2013 | 07:27 PM
ssrogers's Avatar
Ah, that should be perfect. Thank you paul_huryk.
Old Aug 3, 2013 | 05:31 PM
ssrogers's Avatar
What about for the front? I don't want to end up with a rake. The front is currently a little lower than the rear, but the LM7/NV3500 should be a tad lighter than the 305/700R4 and I'm moving the battery to the back. What will fit up front. I already checked and a 245-50-17 is an inch taller than a 245-50-16 but will it fit? I think it's already rubbing somewhere. How do y'all fit 275s up front?
Old Aug 4, 2013 | 06:44 PM
paul_huryk's Avatar
Very easy - just get the right offset on a 9.5" wheel and it fits.
eightsixseven
Dec 16, 2024 01:50 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
