will these wheels fit the rear
Old Aug 27, 2013 | 03:00 PM
onebadredz28's Avatar
Car: 91 firebird vert
Engine: 305 tbi
Found my wheels in 17x10.5 for the rear. The backspace is 7.4 and 44mm offset. Will these work on the third gens without sticking way out? Thanks!
Old Aug 27, 2013 | 06:55 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Re: will these wheels fit the rear
With that offset they would be tucked, not sticking out. You will need spacers to run those, at least 1.5"
Old Aug 27, 2013 | 08:33 PM
Engine: 305 tbi
Hey thanks!
Old Sep 5, 2013 | 09:56 AM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I have 18x10s in the rear with 7.2" backspacing and a 1" spacer and they fit PERFECT. You should get a 1.25" spacer for those. A 1.5" spacer and they may get cut on the outer fender lip over big bumps.
Old Sep 10, 2013 | 01:37 PM
cowansauto's Avatar
How would this play out with a 4th gen 98-up rear axle?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
kah992
Aug 19, 2015 02:55 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
