Lowered 4th Gen Rear Convertible Wheel Fitment Questions
Old Sep 10, 2013 | 01:41 PM
cowansauto's Avatar
On a 1991 Camaro, lowered with Summit springs, 4th gen LS1 rear, what size 18's or 19's would work on this car? I'd like to run at least 18" in the front and a 19x9.5 or even a 20"x9.5" in the rear.
I read that the 4th gen rear spacing is a little different than factory spacing on this car.
Old Sep 10, 2013 | 05:00 PM
86iroct5's Avatar
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
Re: Lowered 4th Gen Rear Convertible Wheel Fitment Questions
18x9 with a 0 offset would fit for sure you could prob go even wider since the 4 gen rear is 2+ inches wider, i would say 18x10s no problem would fit. you are going to rub allllllll day long though, the fender is gonna come down right on the tire. you can get 4th gen offsets +56mm and would clear fun but then your wouldnt have any lip. i wouldnt go larger than 18s but your gonna rub so i guess why not go 19s or 20s lol
Old Sep 10, 2013 | 10:01 PM
cowansauto's Avatar
Originally Posted by 86iroct5
i would say 18x10s no problem would fit. you are going to rub allllllll day long though, the fender is gonna come down right on the tire l
Little confused about your statement. So your saying it will "fit" but wil rub? I'm looking for a wheel & tire that won't rub when I go over bumps and such.
Old Sep 11, 2013 | 09:07 AM
86iroct5's Avatar
in order to get them to fit without rubbing you need to get 4th gen offsets in the rear and 3rd gen in the front, or 4th gen all around with spacers in the front.
this is my friends car, he rubs but the car is functional. now a days rubbing seems to be normal
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
kah992
Aug 19, 2015 02:55 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
