Help me with a wheel fitment
Old Aug 29, 2013 | 01:51 PM
sweet_87_iroc's Avatar
Car: 1987 Iroc-z camaro
Engine: 5.7 Liter
I found a setup and am looking for an expert to help me out. I don't want to run spacers!
The front is:
Offset: 15
Bolt Pattern: 5x120
Rim Width: 8.5
Hub Bore: 72.56
Rim Diameter: 18
The rear is:
Offset: 15
Bolt Pattern: 5x120
Rim Width: 9.5
Hub Bore: 72.56
Rim Diameter: 18
Old Aug 29, 2013 | 02:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Help me with a wheel fitment
Because they are 18s th ey will fit without a spacer but you might end up with a small spacer to bring them out a little as they will tuck under a decent amount. They are 5x120 as well which is not the exact bolt pattern needed, it will work but is not ideal.
Old Aug 29, 2013 | 02:31 PM
Engine: 5.7 Liter
They also offer a 30 offset if that will help avoid spacers. Is there a big concern running a 5x120 over a 5x120.65?
Old Aug 29, 2013 | 02:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
More positive offset will bring the wheel in more requiring a spacer, you would need less not more. But like I said they will fit pretty well as is
z 28 jari
Sep 14, 2021 10:03 PM
Fronzizzle
Feb 9, 2017 09:31 AM
Chad Speier
Sep 24, 2015 12:32 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
