Rear end wobbles at low speeds and noise when taking right curve
Old Oct 29, 2013 | 08:10 AM
adamlinn13's Avatar
The rear end wobbles when I am going slow, I know it could be a tire, but I also noticed that when I am going around a right curve that the left rear wheel makes a noise that I can only describe as a warble.
Is that possibly the wheel bearing or could that be the tire as well?
Old Oct 29, 2013 | 08:37 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Rear end wobbles at low speeds and noise when taking right curve
Could be a bad wheel,tire.axle.severely damaged wheel bearing. You will need to get it off the ground and pull the tire off for inspection.
Old Oct 29, 2013 | 03:49 PM
Z06 FAN's Avatar
Car: 87 Iroc
Engine: built 355, 450HP
Transmission: built 700r4
this might sound stupid but make sure your lugs haven't backed off a bit. Happened to me once long ago. It took weeks before it came loose on me after my tires were rotated.
Old Oct 29, 2013 | 04:25 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Sounds like it could be any of the above. I'd start by checking the lugnuts for tightness. Then get the wheel off the ground (blocking a front wheel)and put it in neutral and start turning the tire slowly. Check the tire for a scrubbed tread, or broken belts. Have someone look at the wheel from behind when you spin it to see if there is a wobble. Take the wheel and tire off and spin the axle checking for a wobble. If everything looks good to that point, then check your rearend housing. If you don't find anything wrong, start checking the other wheels. You should be able to find the problem.
Old Oct 30, 2013 | 11:54 AM
dmwracing42's Avatar
Car: 1984 Trans Am
Engine: 355
Axle/Gears: 10 Bolt, Torsen Diff, 3.73's
Seriously, check the lug nuts lol. I did a rear end swap and put in new LCA's (rod end/poly). I drove it for a bit and there was a kind of metallic rattling noise and the nose dove when turning right (I had just done new Koni's as well so you can imagine my concern). I thought maybe the rod ends were bad, causing the noise. Lo and behold I go outside and go to pull the wheel off and 3 of the lugs came off in my hand. I tightened them up and have never felt so dumb...but yeah long story short, check the lugs lol
Old Oct 31, 2013 | 03:17 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If the lug nuts do turn out to be loose, make sure you inspect the wheel and the lug studs very closely for wear. Usually if the nuts loosen up, it wrecks the wheel and the studs.
hectre13
Dec 11, 2023 08:14 AM
mizz0313
Aug 12, 2015 06:45 AM
BlackBoulder
Aug 11, 2015 11:15 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
