car wobbles/vibrates above 70mph
Car: 1989 IrocZ Convertable
Engine: 350 5.7
Transmission: AUTO 4 SPD, THM 700 R4
Axle/Gears: AXLE REAR, 2.73 RATIO
well title says it all really. i have a convertible, and the frame and hardware and the car in general just starts to get really wobbly (i don't know how to explain it really) and the ride is not smooth the faster i go. not as noticeable until im on the freeway and try to go above 70. i have newer tires, new front and rear struts/shocks, and new front suspension (lower/upper arms, bushings, ball joints) so should i just take it in and have it looked at, or can anyone give me some idea if it might be something else? like i said, only noticeable at high speed. It would be great if i could diagnose this before taking to mechanic so i have some weight behind my argument.
thanks.
thanks.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: car wobbles/vibrates above 70mph
alot of possibilities here
failed struts, weak ones will allow bouncing of suspension
a frozen u joint will cause vibaration shaking due to driveline being bound up every revolution
i had this very issue with my S10 when i got it it had a frozen locked up u joint and had a horrible vibration shaking in it and it ended up bending the driveshaft permanently damaging it
the rear half one anyways(two piece driveline) i ended up taking 1.5" out of a full size chevy van driveshaft and putting it in the truck
but i didnt weld the yoke on exactly perfectly straight after cutting the length out of the tubing(oops) so it has a shaking at about 50 and above hmm..
if you want to eliminate the tires as the possibility then take your flat palm and feel all the way across the tread of the tires all way around them and feel carefully for any bulging or dipping of the tread
if you feel any then it has one or more separating belts in it and this causes shaking viabrating, or worse
pretty common issue with tires and ive seen it many many times over the years mot recently on a buddys 97 grand prix, he had two of his tires do this, very badly too, major bulges in the tread that you could see very obviously with just a quick glance even,
Engine: 350 5.7
wow, guess ill have to check it out or have it looked at.
Car: 88 SC, 89 Silvy, 13 Cruze
Engine: LO3, LO5, LUW
Transmission: 700R4, 700R4, M40-6
Axle/Gears: 2.73, 2.73, 3.94
It could be your tires are out of balance. That waves in the tires Phx is talking about is what mainly happens on fwd cars "dog-tracking" the back tires due to the toe out/in being off to much. I'd take it to a tire shop and see if the wheels and tires are out of balance first. That's what I'd put my money on.
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
sounds like you need wheel blance some times the weights fall of if they where installed correctlly
but more specific where is the wobbling coming from or where you feel it comming from need more info then thats theres alot of possibilities
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
As stated, check tires first, make sure they are balanced.
If that doesn't fix it, look at the driveshaft.
Car: 91 Camaro RS
Engine: GM PP crate 350
Axle/Gears: 3:42 spooled 10 bolt
ive got a vibration over 70 as well when i installed a set of wheels, already got a balance so idk,
Car: 1971 Camaro
Engine: 427
Either they are Not balanced properly, someone over or under torqued them, if they are aluminum, they need to be retorqued,
or,
You have a bent wheel.
Engine: 305 to 350
Axle/Gears: 10 Bolt
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
How do you check for a bent wheel? I would think that over time the structural integrity of anything tends to deteriorate....It would probably not take much deviation from normal specs....but how much bend is too much?
Car: 1984 camaro z28
Engine: sbc 383
Transmission: Th400
Axle/Gears: Moser 9", 4.11 gear
Just curious...because I am having the SAME issue at 70+ mph....
Also, if you take it to a tire shop they will put it on the balancer and that will let you know pretty easily. Bent wheels dont spin easily on the balancer and "hop" which is usually what lets you know that there is definitely a bend in there. Again, this is only if your positive you have a bent wheel and cant find it yourself, which is unlikely.
And you can not balance out a bent wheel. You "technically" can, but only in the sense that the balancer will say it is okay. You still will have a vibration. In the sense of a bad enough bent wheel, there is really no other option than to purchase a new wheel.
Car: 1971 Camaro
Engine: 427
Or have someone follow you and watch the wheels, you can usually see a bent wheel wobble.
Engine: 350 5.7
balancing the tires fixed it. forgot to reply to this thread after i got it fixed.
Linson
Aug 21, 2015 02:12 PM
Its pretty simple
