40 mm offset 5.71 backspace 17 inch rims
Old Nov 17, 2013 | 08:37 AM
87IROC420's Avatar
is there any way i can get these to work with my 87 iroc with spacers
Old Nov 17, 2013 | 08:55 AM
86iroct5's Avatar
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
Re: 40 mm offset 5.71 backspace 17 inch rims
yea you need a 2in spacer.. any wheel with a 0 offset and less than or equal to 9.5in wide will work on a thirdgen.
let me guess they are 4th gen wheels right? probably of the zr1/z06 variant?
Old Nov 17, 2013 | 09:56 AM
87IROC420's Avatar
no the rims are from tire rack i had them on a different car . so a 2 inch spacer all the way around will work? the back will stick out more a little ?
Old Nov 17, 2013 | 10:48 AM
86iroct5's Avatar
they will be equal, a 2in is what you would need, they will stick out 1/4-1/2 further than stock
Old Nov 17, 2013 | 06:56 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
It would really help to know how wide they are...
Old Nov 17, 2013 | 10:36 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
They seem to be a wheel thats 8.28" wide, Probably called a 17x7.5 I would guess. You would want a 40mm or slightly thucker spacer if thats the correct width. A 2" spacer would work ok.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
gord327
Sep 29, 2015 10:18 PM
