wider tires
Old Apr 16, 2014 | 11:59 AM
thorpe991's Avatar
Car: 1987 irocz
Engine: 5.0 305 tpi
Transmission: stock auto
Axle/Gears: stock not sure the ratio
wider tires
so right now im running stock suspension height with stock 16" rims and for tires im running 245 50 16 i want to run a wider rear tire than front but want to keep my fronts a 245 50 so what size tire that is the same height tire as a 245 50 but wider by a inch or 2
a 145 50 16 is H: 25.6" W:9.65"
so i want something that is 25.6" by like 11" or 12" for my rear tires
Old Apr 16, 2014 | 01:33 PM
mt91ta's Avatar
Car: 1991 Trans Am
Engine: Supercharged 383 stroker
Axle/Gears: 4:11, 12 Bolt
Re: wider tires
I ran a 255/50/16 without any issues in the past. Not sure if you can go larger or not, Mike
Old Apr 16, 2014 | 02:24 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: wider tires
You are barking up the wrong tree in a wide 16" tire with a stock 25.75" height, not much available in 245-50-16 or 255-50-16, everything wider is either extinct, or extremely hard to find these days.
An 11" tire is going to spec out at a 275-45-16, which as far as I know is not available at all.
Old Apr 16, 2014 | 03:26 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: wider tires
Yup, 265 45 is the widest I've found and they is not cheap
Old Apr 16, 2014 | 05:25 PM
Javier87z28's Avatar
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
Re: wider tires
255 probably your best bet
Old Apr 16, 2014 | 06:34 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: wider tires
11 inch wide tires on a 16" wheel for these cars just doesnt make sense. The tires just arent available for them and 11" is 3" wider than the wheel.
Old Apr 16, 2014 | 06:54 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: wider tires
How wide are his rear wheels ?
Old Apr 16, 2014 | 07:06 PM
Car: 1992 Camaro RS
Re: wider tires
He said stock 16's so we can only assume 8. Even if it were a 16x12 it's not like there's street tires out there in that size.
Old Apr 16, 2014 | 09:53 PM
Engine: TBI,5.0
Re: wider tires
Yes, it’s always confused me a little when someone says they want to know how wide of a tire they can run saying nothing more than stock 16s or stock 15s.
I think a 255 looks great on my 15in x 8in rear wheels. Not only that but a 255 is as wide of a tire I would put on an 8in wheel.
As has been said theres not much to choose from.
I found this = http://www.tirerack.com/tires/tires....omCompare1=yes
Old Apr 17, 2014 | 05:48 AM
thorpe991's Avatar
Car: 1987 irocz
Engine: 5.0 305 tpi
Re: wider tires
ok so a 255 45 would be the size i would have to go
and i think the stocks are 16x8 and i like the wide tire look on the rear with skinnier tires up front one of my co workers has a 1970s camaro with N50s on the back and hes running 8" wide rims and spacers to clear them so thats what i was looking to do but n50s only come for a 15" rim so i was looking for something close but for a 16" rim
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
