Black Plastic Lug Cover Removal
Old 04-17-2014, 09:21 PM
FL TA's Avatar
Car: 1985 Pontiac Trans Am WS6
Transmission: 4 SPD AUTO Borg Warner 9 Bolt
My TA has the 16" high tech turbo wheels with the black plastic lug nut covers.
The owners manual states use the lug wrench to get them off. Right.
How do you get these damn things off to get to the lugs underneath?
I put a 18mm socket on them and tried twisting them off. All that accomplished was create a cracking sound.
I want to get black lugs and get rid of the plastic stuff. Thanks!!!
Attached Thumbnails Black Plastic Lug Cover Removal-1985-trans-am-ws6
Old 04-18-2014, 06:46 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Black Plastic Lug Cover Removal
Mine are threaded. You can nearly unscrew them from the lug by hand.
JamesC
Old 04-18-2014, 09:30 PM
Chet's Avatar
Car: GTA
JamesC
Same here. I just use an extended socket and remove them by hand.
Old 04-30-2014, 01:43 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
You should keep them,those wheels look great with them and crappy without them
Old 04-30-2014, 02:36 PM
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: 5.7 TPI - LS1 Forged by LME
Transmission: 700r4 - 4L60E
Axle/Gears: 3.23 - 3.73
And if you break them, Dorman sells them.
http://www.dormanproducts.com/p-1602...stener%20Cover
1992 Trans Am
05-10-2023 07:19 PM
Vintageracer
01-10-2020 05:33 PM
Fronzizzle
03-18-2019 08:29 PM
1992 Trans Am
08-08-2015 08:16 PM
3rdgenparts
08-08-2015 07:09 PM
Quick Reply: Black Plastic Lug Cover Removal
