PE-MOTORWERKS Wheel Adapters -Ebay
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
Has anyone ever used these wheel adapters? Pair of 2 for only 60$ shipped and they are hub & wheel centric (they have the lip) that's miles cheaper than the hawks ones where they want 180$ for a pair of theirs. Quality looks good and I've seen others on different sites liking them.. but I noticed the ones with the lips to center the wheel.. all say there may be issues with in 82-03 Camaro due to hub height, and to email for more info which I did but quicker an answer the better
Really all I'm asking is has anyone used these?
http://m.ebay.com/itm?itemId=380840929970
They say "The Wheel-centric lip on the spacers in this listing are 70.5mm in diameter."
They look very good quality and have a ton of positive feedback, I'd have to assume at least someone on here has used them
Thanks in advance, Sean
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: PE-MOTORWERKS Wheel Adapters -Ebay
I liked the ones I got from lugs-n-stuff. They're not going to fit the front because the front hubs arent really hub centric. But they were hub centric on the rears.
eh rears dont bother me.. i have 4th gen rear so the rims fit perfectly. | i ended up buying a used set of 2" Adapters from a buddy of mine.. came right off his firebird that had same rim style lol. wheels/tires are mounted and fit perfectly
punkmaster98
Sep 8, 2015 09:45 PM
