Help needed!!!
Old Jul 18, 2014 | 04:42 PM
TnFatDaddy's Avatar
Car: 92 RS
Engine: 305 TBI
Axle/Gears: 3.08 soon to be 3.42
Help needed!!!
Ok guys I have looked through here so much I have confused myself...which aint hard to do...I would appreciate any help I can get. Here is what I have 92 RS stock brakes and stance at this time. I bought a set of zr1 with high offset. 17x9.5 / +54 offset / 7.30 back spacing for front and 17x11 / +50 offset / 7.90 backspacing for rear. What size spacers and tires would you all recommend. I am thinking 2" spacers all around and 245/40/17 front and 275/40/17 rear. All opinions welcome.
Old Jul 18, 2014 | 08:18 PM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Re: Help needed!!!
From what I have seen recommended here 56 offset requires 2.25" spacers in the front.
The rear would need 2" spacers.
Please mock up a wheel on your car and measure what you can get away with. People recommended 2" spacers with my 38 offset 17x9.5's. If I went with 2" spacers the wheels would be hanging out too far.
Tires I would use with that setup would be 275/40 fronts and 315/35 rear. If you prefer the slightly stretched look and are lowered then 245/45 and 275/40 will work great and probably have better transitional response than my choice.
Places to pay attention for clearance issues are the rear bump stops and front strut/tie rod end.
Old Jul 18, 2014 | 08:55 PM
TnFatDaddy's Avatar
Car: 92 RS
Engine: 305 TBI
Re: Help needed!!!
I appreciate it Ram.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
