Thinking of XXR 536 in 17x9
Car: '87 IROC-Z
Engine: TPI 5.7
I really want 17x9s for pleasure driving, autocross and track days. I don't want to go any wider or taller. How do you think the fitment on these wheels will be? Anybody got em in this size and offset (+25mm)?
http://www.nlmotoring.com/XXR-536-Wh...p/53679209.htm
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Re: Thinking of XXR 536 in 17x9
6" back spacing isn't gonna work on the front. Probably will need close to a 3/4" spacer.
0 to 8mm probably would fit better on the front.
Not liking the 5x120 bolt pattern either but many do it anyway.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
You can run those wheels with the proper adapters - 5 x 120 and 6" BS are not going to be bolt-on easy.
There are other options on the market - have you checked those out also?
Car: '87 IROC-Z
Engine: TPI 5.7
Brinkkl2000
Aug 4, 2018 08:29 AM
