New wheels but will they fit
Old Dec 23, 2014 | 08:06 AM
claus290373's Avatar
Car: Trans Am gta 5.7 1989
Engine: 350 tpi
Transmission: th700r4
Axle/Gears: BG 9 bolt
Hey
Will whells 8.5 and 9.5 x19"
et20 fit my 1989 firebird ?
They come of a BMW e60/e61
And yes i know they are 5x120
Thaks Claus
Old Dec 23, 2014 | 12:17 PM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Re: New wheels but will they fit
The rears probably will work fine. The fronts "might" have interference with the strut.
I say might because if the wheels were 17" they for sure would be hitting the tie rod and strut. Going to a larger diameter eliminates the tie rod as a problem and the strut moves farther away from the rim lip.
Old Dec 25, 2014 | 06:28 PM
Night rider327's Avatar
Car: 1988 Camaro
Hub center bore will be alittle big and wheel will have to center off studs, which aint great, but not bad either.
The F body hub bore is 70.3
That BMW wheel hub bore 74.1
I don't have info on the offset/back spacing
Scamo-2.8
May 20, 2016 07:01 PM
kah992
Aug 19, 2015 02:55 PM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
milk
Aug 10, 2015 06:26 PM
