can someone check my spacer info
Car: 88 iroc vert
i got the big brake upgrade c5 brakes and im using the 4th gen 10 spokes, will this info work for my spacers before i order??
its from motorsport-tech.com
1988 CHEVROLET CAMARO
Your Bolt Pattern: 5x120.7mm
Your Hub Diameter: 70.3mm
Type: One Piece Adapter
Hub Centric to Car Only
Thickness: 45mm
Stud Size: 12x1.5
Diameter: 5 by 120.7 (4.75 inches)
Price each: 55.00
Total Quantity: 2
Thickness: 45mm
Stud Size: 12x1.5
Price each: 55.00
Total Quantity: 2
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
Re: can someone check my spacer info
factory 4thgen offset is 56, so you will need a 2.25in spacer to achieve a 0 offset which is ideal and will fit without rubbing.
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Your big brake upgrade widens the front stance from cutting stock rotors into hubs correct?
If so 2.25" adapters would push the wheels farther out than needed. Without knowing the thickness of the new disks I would be hesitant ordering spacers until I knew for sure what the thickness was.
If I was to guess I would think a 2" spacer might fit better.
This is a picture of my car with stock brakes and zero offset 17x9.5 wheels.
Car: 1987 GTA
Engine: TT LC9
Axle/Gears: 3.50
I have a pair of 1.75 thick, hub and wheel centric for sale if you're interested. I'm asking a bit more than what you're looking at, but they're really high quality.
