Tire Scrub
Old Feb 22, 2015 | 03:13 PM
tigerZ28's Avatar
Tire Scrub
I'm having a issue with my tire contacting the rear fender at highway speeds, usually 65+mph, however the only scrubbing is on the passenger side. I have some older style Corvette Rallys that I purchased from Summit with the correct back spacing. The questions I have is why would only one side be scrubbing and what are some suggestions for solutions. I replaced the rear shocks and springs, moog variable rate springs and Monroe sensa-trac shocks, which helped but did not completely solve the issue.
Thanks for any and all help
Old Feb 22, 2015 | 04:23 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Tire Scrub
Wheel specs and tire size please
Old Feb 22, 2015 | 04:56 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Tire Scrub
The rear axle is offset in these cars from the factory
A adjustable Panhard bar will help you fix that.
As said above, more tire wheel info is needed.
Old Feb 22, 2015 | 05:29 PM
tigerZ28's Avatar
Re: Tire Scrub
15×9 and BFG Radial T/A P295/50/15
Old Feb 23, 2015 | 06:58 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Tire Scrub
What backspacing?
Sounds like u need an adjustable Panhard bar to center up the axle, but I have a feeling you may still have problems unless the wheels fit really well and you roll the fenders lips.
Any pics you could post?
Old Feb 23, 2015 | 07:35 PM
tigerZ28's Avatar
Re: Tire Scrub
Im looking at a 4 1/2 offset. The main issue is that the tire is a bit wider than the fender can allow. I'll try to get and post pictures momentarily.
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Re: Tire Scrub
I have heard of 15x10 and 15x8 rally's but never 15x9.
You sure that's the size?
Old Feb 23, 2015 | 08:00 PM
tigerZ28's Avatar
Re: Tire Scrub
https://www.flickr.com/photos/130706...3/16422329727/
https://www.flickr.com/photos/130706...3/16009862213/
https://www.flickr.com/photos/130706...3/16629621575/
It may be a 15x8, that was my original thought. I came up with the 9 by measuring the tire on the wheel minus an inch. Hopefully these pictures help.
Old Feb 24, 2015 | 12:33 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Tire Scrub
If the wheels measure 9" wide, they are 8" wheels with 4.5" of bs
You need the adjustable panhard bar for sure, and see what happens, if it still rubs both sides, then roll the fenders and you should be good to go.
Old Feb 24, 2015 | 09:16 PM
tigerZ28's Avatar
Re: Tire Scrub
After further investigation I have 15x10 wheels (I found the receipt) I have the 4.5 offset. Would coil spring blocks fix the issue?
Old Feb 26, 2015 | 12:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Tire Scrub
If tbey are 15x10 with 4.5" of bs they will never fit right with raising the back of the car a few inches. Best bet is probably moog iroc replacement spring since they are pretty stiff and generally raise the car a few inches.
Or sell them and get proper wheels
Old Feb 26, 2015 | 08:37 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Tire Scrub
Air Bags/Drag Bags "in" the springs.
You don't want to use the "T" fitting on the are bag hoses. You run them independently . One line for each one.
The "T" fitting will allow air transfer from one bag to the other. You don't want that.
A 295/50r15 on a 10" wide 4.5 bs wheel will be sticking out of the well past the flair.
The option above is really the only one if you insist on keeping that combination.
If you cant now ? At max inflation you should be able to put people in the back seat.
Old Mar 1, 2015 | 04:31 PM
tigerZ28's Avatar
Re: Tire Scrub
I'm considering putting 275/60/15 tires on it, hoping to pull the overlap in.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
