Problem keeping center caps on front tires
Old Mar 18, 2015 | 12:12 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Hey everyone,
I have an 84 TA with 15" formual wheels and I can't keep the front center caps in the car. I bought the set that has the metal retainer in them and on the rear they fit amazingly well. On the front, the metal retainer bumps against the bearing cover and no amount of modifying gets it to stay.
I've tried using them without the metal retainer clip in them and they don't stay secure. One good bump and the cap goes flying off.
Any thoughts on how to secure the caps? It's getting expensive having to replace them every couple of months because I lose the two front ones.
You can see the wheels I have if you click on my trans am link in my signature.
Old Mar 18, 2015 | 12:20 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Problem keeping center caps on front tires
Let the caps ride "shot gun" witcha! Just kidding!
I lost a few over the years.
take a drop or 2 of superglue and put on the tabs of the plastic caps. Name:  dontknow.gif
Old Mar 18, 2015 | 01:36 PM
Ozz1967's Avatar
Car: 1984 Trans Am
take a drop or 2 of superglue and put on the tabs of the plastic caps. Attachment 290092
I'll give the superglue idea a try. Maybe RTV as well? Something to make them grip into the wheel a little better perhaps?
Old Mar 19, 2015 | 12:45 AM
Manic Z's Avatar
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
I had the same problem with my iroc caps in one of my front iroc replica rims. Ironically, the problem was with the one made in the USA, while the other three that say made in china had no problem. Go figure.
I used a couple dabs of crazy glue to keep it there. No problem after 2 years. Just gotta be careful when it comes time to remove it.
Old Mar 21, 2015 | 07:29 AM
FrankieRider2's Avatar
Car: '88 Bright Red GTA UPC 81U
Engine: 5.7L TPI
Axle/Gears: 3.27:1
Always used a dab of silicone with mine when I drove them regularly. Tried super glue once but it tried to eat into the little mounting clips so I changed to silicone instead. Also works great on the black screw on lug nut covers.
Old Mar 30, 2015 | 12:14 AM
Ozz1967's Avatar
Car: 1984 Trans Am
I've never had an issue with the black lug nut caps, only the center caps.
What kind of silicone...just RTV black? Or another style?
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
kah992
Aug 19, 2015 02:55 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
