Which wheels can fit my Camaro 91 !
Hi guys,
Now it's time for me to bring out the beast from the garage
and I need help with what kind of wheels will fit my Camaro 1991.
Any suggestions ???
Size: 18' or 19' ?
Width: 8 or 8.5 front, 9 or 9.5 rear ?
PCD: I have 5x120.65 but can 5x120 fit ?
Offset: I was thinking of ET20 ?
Tires: 235/50 ?
Thanks for any ideas !
and I need help with what kind of wheels will fit my Camaro 1991.Any suggestions ???
Size: 18' or 19' ?
Tires: 235/50 ?
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Re: Which wheels can fit my Camaro 91 !
Here is my take...
Tire space is limited, so I would go 18", otherwise you get a really short sidewall.
Remember a tall tire makes the car even taller, or causes more clearance headaches on a low car.
As for width & offset, you need to first match the tire width, then use offset to center it in the wheel well.
Not sure why you are considering a big wheel & picking a scrawny 235 tire. I'm running 275's & considering bigger on all 4 corners.
Also get the correct 4-3/4" B.C. / 120.65mm.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Don't even bother with 8" or 8.5" wheels - the tires that fit are too narrow for performance applications. You really want a 9.5" wheel with a 275 width tire on all 4 corners like Lonnie P mentions above.
In terms of wheel diameter, don't go larger than 18" - the sidewall is too small, so the ride and ability to negotiate road craters goes into the ******* real quick.
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
The only reason I want to go from 17's to 18's is so I can get more backspace (tie rod clearance issue) to run a wider tire.
Thanks for the info !
I forgot to mention that my camaro i s a V6 and I don't race with it
just need it for everyday.
But you all would say that I should use a PCD 5 x 120.65mm and not 5 x 120 ?
just need it for everyday.But you all would say that I should use a PCD 5 x 120.65mm and not 5 x 120 ?
kah992
Aug 19, 2015 02:55 PM
