Tire size
Old May 18, 2015 | 05:39 PM
Buloushie's Avatar
Car: 1986 Z28 Iroc
Tire size
I just picked up a set of 17 in GTO wheels and stumped on tire size
Should I go with 255-45-17 or 2455-40-17 on all four wheels.
Old May 19, 2015 | 08:47 AM
86iroct5's Avatar
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
Re: Tire size
275/40/17 with a 2.5in spacer should be nice
Old May 19, 2015 | 09:07 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: Tire size
I would go 245-45-17 as the wheels are not wide enough for 275 tires and 255 has less choices to pick from...
Old May 19, 2015 | 10:12 AM
86iroct5's Avatar
Re: Tire size
gto rims are 17x9s no? in the case of 17x8s then yes paul is right
Old May 19, 2015 | 10:59 AM
Buloushie's Avatar
Car: 1986 Z28 Iroc
Re: Tire size
Wheels are 17-8 not 17-9. Wish they where 9 inch wide. That's why I'm leaning towards 245-45-17 on all 4 wheels. The offset is 40mm which means I'll need 1.25 inch spacers
Old May 19, 2015 | 11:51 AM
86iroct5's Avatar
Re: Tire size
you want the offset as close to 0 as possible. you would ideally want a 40mm spacer which is 1.5748 inchs. i thought GTO wheels were 4th gen fbody specs. 17x9 +56mm. so disregard my first post.
i would go with the 245/45/17 and the 1.5inch spacer
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
