Wheel question
Old Oct 21, 2015 | 08:36 PM
bamaboy0323's Avatar
Wheel question
I'm so confused about trying to fit new wheels so please bear with me. So I'm pretty hell bent on running 19x9.5 wheels on all 4 corners on my 92 camaro. Wheel specs are 19x9.5, 5x120, 72.60 Center bore, and +20mm offset. Will I be ok by getting a 1" inch adaptor/spacer or would that be too big of a spacer? Could I run 19x10's on the rear without any issues?
Old Oct 22, 2015 | 08:43 AM
86iroct5's Avatar
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
Re: Wheel question
that set up should be fine. i think you nailed it
