17x10 on third gen?
17x10 on third gen?
Has anyone see or achieved running a 17x10 on a third gen? Found a decently nice set of american racing wheels that are hard to find and really want to get them but 10 wides are a little big. Has anyone pulled this off or think I would be able to make it work?
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Re: 17x10 on third gen?
I run 19x10 on the rear of my 92 with 3" wheel spacecrs. I have 18x8.5 on the front with 2" spacers. If the offset is right or you can use the proper size spacer it should work.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
17' x 10" fits on the rear, no problem.
In the front, it is going to either hit the tie rod or stick out a tad. Optimal size is 9.5" wide for a 17. You move up to 18 and things change - it will clear the tie rods and tuck in with the right offset.
bluegrassz
Aftermarket Product Review
Apr 11, 2017 02:15 PM
firechicken1992
Oct 30, 2015 07:45 PM
zman1969
Oct 25, 2015 11:16 AM
